Ignition Switch wire on '96 2500
Old Mar 16, 2003 | 10:50 AM
D4Fritz's Avatar
Can anyone tell me which wire is the Ignition Switch wire on the steering column. I was told that on a 97 it was a light Green and brown, However my '96 does not have a light green and brown wire. Is there an easy way to locate the ignition wire through testing.
Old Mar 16, 2003 | 12:15 PM
redramnc's Avatar
Re:Ignition Switch wire on '96 2500
According to the diagram I have it is 12ga DB (dark brown?) from switch to fuse 9 (10A) then 22ga LG-BK to PDC. This is the from Popular Machanics CD for 96 BR2500. Check your PM because I will try to send the screenshot.<br><br>
Old Mar 16, 2003 | 03:55 PM
Smokee's Avatar
I just installed the pac-brake on my '94. In the instructions, the years covered would include your 96. The ignition wire is the mid-blue #14 in the harness at the bottom of the steering column. I had to remove the web-like harness to find mine. The wire was in the middle of the bundle. There are several othe blue wires there, but no other #14.<br>george
popeyesides
May 11, 2006 02:04 PM
CStroked
Jul 7, 2005 10:55 AM
Stormin_Norman
13
Jun 23, 2003 12:20 AM
KATOOM
Apr 23, 2003 06:53 PM
TPilaske
16
Nov 22, 2002 08:15 PM
