HELP buddies dmax
Old Jan 5, 2009 | 11:33 AM
NM12VALVE's Avatar
HELP buddies dmax
If any one is familiar with d-max's, we just swapped out his injectors with some remans, its an 01, and now just poors out white smoke. Just checked all ic boots and seem to be ok, can hear the turbo going. Any help would be great thanks
Old Jan 5, 2009 | 11:57 AM
Dwitt0187's Avatar
sounds like one of the remans is stuck open
danny
Old Jan 7, 2009 | 09:58 PM
VFIMechanic's Avatar
Bad injector.
Old Jan 7, 2009 | 10:07 PM
67HotRod's Avatar
Bad injector or maybe a leaking injector cup.
Old Jan 7, 2009 | 10:15 PM
collin_bucko's Avatar
did you get the reman's pop tested before installing them?
Old Jan 7, 2009 | 11:18 PM
torquefan's Avatar
From what I was told in training, you need to drain all the coolant from a Dmax before removing the injectors, or the coolant's pressure can dislodge the injector cups. Don't know if this is your problem or not, but I thought I'd mention it. I was quite surprised to hear it.
kevinv
Apr 7, 2009 10:59 AM
5HRacer
Jul 2, 2004 06:27 PM
turboblue
Oct 27, 2003 07:48 PM
SpitDirtCom
Mar 27, 2003 08:06 AM
