head gasket
Old Dec 2, 2006 | 07:12 AM
rambod's Avatar
head gasket
good morning everyone. my truck has a head gasket leaking externally. what head gaskets would you use? cummins or felpro any preffrences would be appreciated.
Old Dec 2, 2006 | 10:58 AM
JKM's Avatar
JKM
I would definetly go with a cummins gasket, now might even be a good time to stick in a marine gasket and some studs
Old Dec 2, 2006 | 12:19 PM
rambod's Avatar
what is the diffrence between a marine and a factory gasket? do i need it even if the vehicle is pretty much stock.
Old Dec 2, 2006 | 12:24 PM
blackdiesel's Avatar
Registered
what were you doing when you blew it? do you know your boost pressure? head pressure? ya know what i think on this
Old Dec 2, 2006 | 01:14 PM
rambod's Avatar
head gasket is not blown just seeping at the right front corner of head.
Old Dec 2, 2006 | 01:57 PM
displacedtexan's Avatar
IIRC the marine gasket is a little thicker. And my general feeling is if something breaks, and a stronger option is avalliable, it gets replaced with the heavier duty version. Even if you don't "need" the heavier duty version. (unless the upgrade part is completely cost prohibitive)
Old Dec 2, 2006 | 11:32 PM
OHFarmboy's Avatar
When I did mine I got one from Cummins, and it couldn't hold up to the old 12v! I went through 4 hgs. But with your truck bein stock I would definatley go with Cummins, get one through a big truck store not the *******, about $60 bucks from a KW store! More than twice that at the dealer.
Old Dec 3, 2006 | 01:30 AM
XLR8R's Avatar
Is the marine gasket merely thicker, or is it constructed differently from the stock one?
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
