Hard starting on Hill....
Old Nov 11, 2004 | 10:34 AM
GreenMachine5.0's Avatar
I park my truck, 99 24v 2500 cummins, on a hill, with the front facing up the hill. when i'm parked like this sometimes the truck take a little while to start.
My concern is that the lift pump may have taken a ****, and secondly, now i'm abusing the injection pump and that will prolly take a dump.
On flat ground I havne't had any problems starting. It eventually starts on the hill, but sometimes I have to try starting it like 2 or 3 times and pump the pedal. Other times i just crank and after three seconds or so it fires.
I had to replace the inj pump last dec, and it still has a warrenty on it.
I'm gonna try to get some codes tomorrow, just seeing what you guys think.
Josh
Old Nov 11, 2004 | 10:37 AM
Dr. Evil's Avatar
how about after its wrarm??? is it hard starting then? Usually a trashed IP will start good when its cold but cause problems when its warm.
Old Nov 11, 2004 | 01:42 PM
Lakemann's Avatar
What year truck?I had a 99 that did the same thing,after about 10 trips to the dealer,and months w/o the truck,Dodge finally did a buy back on it!
Old Nov 22, 2004 | 07:52 PM
gameofkings's Avatar
First try parking with the eng downhill. If there is a change I would suspect the lift pump. Also does this change with the tank full as compared with 1/4 tank? Has the fuel filter been changed lately? Lift pumps have a history of failure! I would certainly check the lift pump output pressure first! Good luck
Old Nov 23, 2004 | 12:49 AM
KATOOM's Avatar
Is there a time fram involved? If it takes a while to hard start, say like over night, then I would suspect a possible air leak in the fuel line allowing the return of the primed fuel? Just a thought.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
IntakeRacing
Feb 10, 2007 04:32 PM
Lilfoot
Jan 3, 2007 07:15 AM
