GEN light?
GEN light?
GEN light came on this morning, after drving for about 15 miles.
First time ive seen it in about 5 years. once i noticed it, i looked volatage guage was hanging pretty low.
is this just the alternator going?
That's the most common , the regulator is in the ECM , but also check connections , battery pos + grnds , fusible links , fuses .
need to test the alt directly , the 2 small wires on back of alt are for control of alt , disconnect both , then jumper one to ground & other to battery , but only for about 30-60 seconds , this is what the regulator does , it turns on the electrical field to the alt , making charge at max - this is why just for a minute or less , because if the alternator is working it can run too hot .
If it works then you need to find out why not , does the tack read RPMs , this is one of the things the computer uses , the crank sensor .
One of the common things when the alt quits is the brush's .
There's a couple ways to go , rebuild your self or get new .
This is where I go .
http://www.fostertruck.com/dodge/default.htm
anonymous_1
13
Apr 30, 2020 04:29 PM
BRUISER
Feb 2, 2015 11:25 AM
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
