gear puller for ip
Old Apr 7, 2005 | 09:27 PM
greenworks's Avatar
gear puller for ip
is there a "special"puller or a simple unit that uses the cover as a base to pull from like a small steering wheel puller etc. I am thinking my ip took a dump since it showed the 0216 code today but it only smokes wjite for 30 seconds on the odd start and seems to be holding its power well. I want o be ready when this thing goes south.
Old Apr 8, 2005 | 01:54 PM
RCW's Avatar
RCW
The lift pump is electric and fully self-contained, and takes no special tools. Just do a fuel pressure test to be sure it is the lift pump before you jump.
Old Apr 8, 2005 | 01:56 PM
greenworks's Avatar
RCW "ip" means injection pump as vp 44 and yes it does take at least a gear puller to remove the pump gear I am trying to find out if it can be done without a expensive say snap on tool. Anybody??
Old Apr 8, 2005 | 02:09 PM
Haulin_in_Dixie's Avatar
I just use a steering wheel puller that I have here, I do have a couple of different sizes. If I remember right, I had to purchase a couple of bolts for it to get the right length. Leave the nut on loose to catch the gear and use some protection for the cam shaft, like the little cap that comes on the puller.
berner
22
Apr 29, 2007 12:36 PM
RobD
Jul 22, 2006 08:58 PM
puffmagicdiesel
Mar 28, 2006 08:12 PM
Diesel-Dan
Apr 5, 2004 02:18 PM
Diesel-Dan
Mar 31, 2004 09:57 AM
