fule problems
Old Jan 16, 2009 | 12:07 AM
usmarine110786's Avatar
fuel problems
when i go to get on it at 2300 rpm it cuts out like its not getting enough fuel maybe a computer problem or fuel pump or injector pump can someone help??
Old Jan 16, 2009 | 05:26 AM
77machomopar's Avatar
what year truck?
Old Jan 16, 2009 | 07:17 AM
1-2-3's Avatar
Just a plain ole guy
Have you tested the fuel pressure. It may be dropping to nothing
Old Jan 16, 2009 | 04:00 PM
the truck is a 2001 and i havent tested the fuel lines but when it was put on a scanner it said there was a bad connection with computer. also wondering if i went ahead and put my edge juice in if it would fix the problem or make it worse?? thanks for the help also i have edge stage 3 injectors, k&n cold air intake and a 4" straight exhaust.
Old Jan 16, 2009 | 11:21 PM
johnh's Avatar
what's the code?
Old Jan 17, 2009 | 05:27 AM
Adaminak's Avatar
Plugged/dirty fuel filter?
Old Jan 17, 2009 | 10:48 AM
rollincoal01's Avatar
Fuel cut/ Overboost? I don't see a boost fooler in that list of equipment I see there. Hook up you Edge Juice & see if it still does it. The module will do boost fooling. If it still cuts out, I'd say look at your fuel filter, and lift pump pressure.
Later,
Tommy
DrBob
Aug 5, 2007 09:39 PM
old dog
Mar 22, 2006 12:53 AM
wildcargo
Jan 31, 2006 08:44 AM
Central Oregon
Dec 19, 2004 10:43 AM
winkle
35
Oct 8, 2004 01:48 PM
