Error Code - P0628 Low Voltage Detected at The Fuel Lift Pump Relay
Error Code P0628 - Fuel Pump Relay Control Circuit Malfunction / P0628 Low Voltage Detected at The Fuel Lift Pump Relay.
Does this mean I will have to replace the entire pump or can you replace the relay only?
Cummins Guru
If you have the external fuel pump on the fuel filter housing I would replace that first. Does the fuel lift pump relay click when you bump the starter? If not replace the lift pump relay
Cummins Guru
I'm sorry the fuel pump relay is intergrated into that ecm module. You most likely have a bad fuel pump. Check power and ground and lift pump and if ok replace the lift pump. There is a retrofit fuel pump available which converts your external fuel pump to intank type fuel pump. Also includes flash update to ECM and wiring harness to convert to intank type pump.
Thank you!
Cummins Guru
ECM is a sealed module and it mounted on the left side of the engine block. Lift pump is mounted on fuel filter housing.
1 - ENGINE CONTROL MODULE (ECM)
2 - ECM MOUNTING BOLT
3 - 50-WAY CONNECTOR
4 - SUPPORT PLATE
5 - 60-WAY CONNECTOR
4 - SUPPORT PLATE
Just changed the transfer pump but still get codes: P0628 & P0633. Gonna take her out for a test drive now and see what happens. Do you have to perform a reset or is there still trouble? Somewhere I saw a list of codes but can't find them now, anyone have the link to the page with the error codes?
Thank you!
Thank you!
Harley1
Nov 25, 2009 06:40 AM
ctd4stan
Mar 19, 2009 08:35 PM
hector44
Feb 21, 2008 05:00 PM
