Engine Speed Sensor/Crank Sensor - 12 valve
Trying to replace the engine speed sensor. I removed the two nuts just above the dampner. Is there another bolt that needs to be removed to pull the sensor from the harness?
Thanks
Thanks
I think that what your asking is , is the harness bolted on , have not done one on a Cummins yet , but every other that had a speed sensor next to a spinny thing , had a metal strap that held the harness from getting into the balancer
, then up stream you'll find a connector .
desertoy
Jul 18, 2012 08:13 AM
Gabe32
16
Feb 22, 2007 06:37 PM
Diesel Junkie
Jul 4, 2006 04:04 PM
