engine codes
Old Nov 17, 2004 | 05:52 PM
ollieman's Avatar
engine codes
my check engine light came on and the truck started to run rough.It will rev up and down when going around 40-50mph.I took the truck to a local garage to have them hookup and scan what codes it was putting out and they said it was a code #po1693 and something about a J TEC Controller and we can not find out what that code is and what a j tec controller is. Looked on this site under codes and no listing . I really dont want to have to take this to a dodge dealer at a gazillon dollars per hr
does anyone have any ideas I would really appreciate some help
thanks
Old Nov 17, 2004 | 08:34 PM
RCW's Avatar
RCW
The code should be P 1693, and it is a companion code to P 1690 which is low fuel pressure.
From the code, I suspect you have a 24 valve second gen truck, and likely have a failing lift pump.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
alltimelow1
Apr 6, 2005 07:28 PM
