Electrical Problem and Alternator shows NO output!
Old Jan 16, 2008 | 12:32 AM
  #31
Katmandu's Avatar
Question
Originally Posted by sweeney186
the 98 should have 12v key on pin 12 gray conn-but the diag is the same for 12v & 24v-which is prob not true.there have been many mistakes in their diag's over the years.the 97 diag shows only 2 12v feeds pins 2,12 blk conn.
you do have 12v at the right places-one other thing can shutdown your pcm-a shorted crank sensor.
I should clarify that this truck is an EARLY 98 (Made 11/07) 12 valver. I'm sure the PCMs are different. Should "probably" be the same as a 97 then I assume.[/quote]
I have NO power on PIN #12 key-ON. Is this correct then ?
Is this the ESS (Engine Speed Sensor) near the damper ? Or the one located at the back of the engine ???
Old Jan 16, 2008 | 09:46 AM
  #32
infidel's Avatar
There is no sensor (CPS) at the back on the engine, that's a 24 valve thing.
'94&'95 are the only years that have the same PCM, all the other 12 valve years are different.
Old Jan 16, 2008 | 10:05 AM
  #33
vzdude's Avatar
DTR's 'Go to Guy'
97 or early 98 , either way, if it affecting all the guages, it's a pcm or ccd bus issue.
Old Jan 16, 2008 | 10:25 AM
  #34
Katmandu's Avatar
Question
Where's a good place to find a used PCM ?
Do I look for a 97 (since it's a 12 Valver and built 11/1997) or go with a 98 ?
Old Jan 16, 2008 | 10:35 AM
  #35
vzdude's Avatar
DTR's 'Go to Guy'
Best thing to do is to get the number off of your old one to match it up. MANY different options. Try car-part.com too. The website will automatically sort by closest parts.
Old Jan 16, 2008 | 10:45 AM
  #36
Katmandu's Avatar
Arrow
1998
05014155AA
56040139AA
56040139AB
From this website....
http://www.aa1car.com/library/2004/c...ailability.pdf
I still need to do the final check on that CPS. It's gonna have to wait a bit. I work 3rd Shift and have been up A LOOOONG time.
Old Jan 16, 2008 | 10:55 AM
  #37
vzdude's Avatar
DTR's 'Go to Guy'
You need the number off of YOUR pcm. Should be a label. Even if the pcm has been flashed ( which changes the number ) ( look for a label either on the core support or the pcm itself), if you get me those numbers , I can give you a list of all pcms that will work. And a price on a new one too!
Old Jan 16, 2008 | 11:08 AM
  #38
Need95-00CTD's Avatar
first things first, pull apart the plugs on your PCM, find the light green wire with a black stripe and check to make sure you have voltage, if you don't, either your fuse is blown, a wire is cut, or shorted out somewhere. Thats what happened with my problem, find the short, find your problem.
To test the PCM I just spliced into the green and black wire that runs into the PCM, cut it, and spliced it right to the cigarette lighter (only thing I knew had power with the ignition on). When I got back my gauges I knew the PCM wasn't dead.
Old Jan 16, 2008 | 11:21 AM
  #39
vzdude's Avatar
DTR's 'Go to Guy'
I would agree.....that is still a possibility. Double check that first. There are NUMEROUS splices in that wire too! You did double check fuse 4 & 9 too right?
Old Jan 17, 2008 | 12:37 PM
  #40
Katmandu's Avatar
Arrow
Yes. Both are GOOD.
Old Jan 17, 2008 | 12:38 PM
  #41
Katmandu's Avatar
Question
Which plug and position is it on ???
Old Jan 17, 2008 | 02:52 PM
  #42
I don't recall. IIRC its the plug closest to the drivers side, and the 5th from the left on the bottom, but it doesn't take long to pull the back cover off of it and trace the right wire to the right pin. Make sure you check the pin itself, not the wire running into it, as infidel often states the connectors in these things are prone to cracking pins or losing them all together.
Old Jan 21, 2008 | 08:09 AM
  #43
Katmandu's Avatar
Question
Ok, I've got a PCM (used) coming in the mail.
A local mechanic here says I "may" need to have the Dealership REFLASH it to make it work.
It's my understanding that 12 Valvers don't need the PCM to run.
Do I really need to get the PCM reflashed from the Dealership or is this unnecessary ?????
Old Jan 21, 2008 | 10:43 AM
  #44
vzdude's Avatar
DTR's 'Go to Guy'
As long as it is a used one, it may run with some lights and such ( check engine ect, ect,) . The dealer may have to reprogram the VIN for things like abs and such, but the basic functions should still work ( like charging and all!)
Old Jan 22, 2008 | 07:23 AM
  #45
Katmandu's Avatar
Arrow
It's the exact same # 56040139AC. I'm hoping it's plug and play.
It should be here tomorrow.
