Dtc P1693,
Old Dec 27, 2009 | 07:07 PM
dccjml's Avatar
Dtc P1693,
Dodge 2000 Dully, 24v turbo Diesel. I have a check engine code P1693. My Tac needle goes to 0 and I loose power. After awhile the Tac starts working again and power returns to normal. I am reading two different causes out of a book and on the internet. One is P1693, DTC Detected in companion JTEC Module, the other is P1693, DTC detected in EMC or PCM. Niether one sounds good, what do I need to do in order to fix this thing and can I drive it with this code or will it hurt the engine.
Old Dec 27, 2009 | 07:13 PM
Shovelhead's Avatar
Administrator / Scooter Bum
P1693 is a code that tells you there is a malfunction code stored in the ECM.
You need to pull THAT code to see what component is malfunctioning.
It sounds like a possible crank position sensor, but you need to pull that code before you start spending $$$.
Old Dec 27, 2009 | 07:19 PM
dccjml's Avatar
Consider me a rookie, what do you mean (pull that code)
Old Dec 28, 2009 | 07:32 AM
patdaly's Avatar
Scan that code, P01693 is what they call a companion code, a code stored in another computer, in this case the ECM on the side of the block. Po1693 is simply telling you that computer is reporting a code.
Dunno why, to me it would have been just as easy to send the codes as it would have been to send a code reporting a code, but then that's why I don't make the big bucks.
Old Dec 28, 2009 | 12:13 PM
dccjml's Avatar
Thanks for all the help. I'm checking to see if I can pull the code with a friends help from Advanced auto.
Old Jan 2, 2010 | 10:37 AM
XJJoe01's Avatar
I think Shovelhead is right on the money with the problem and the sensor isn't a million dollars like a new APS from the Dodge or Cummins dealer or a VP44.
Joe
Dinner
May 27, 2020 11:48 PM
1882
Aug 21, 2006 02:27 PM
salty mule
Mar 17, 2004 05:59 PM
dansdodgediesel
Jan 2, 2004 04:30 PM
James Lucas
Oct 8, 2003 04:57 PM
