Cracked U joint, need help!
Old Mar 6, 2010 | 02:39 PM
cheadlesram2500's Avatar
My U joint has cracked! Took my truck to the Dodge dealership and they are saying that it is smarter to buy a new driveshaft than replacing the U joint. Dodge said it will be 395$ for parts and labor if I go with the new driveshaft. Does this sound reasonable? I don't know what to do. Should I buy the new driveshaft or buy a new U joint??
Old Mar 6, 2010 | 03:33 PM
rich's Avatar
unless your driveshaft is damaged i dont see why you need a new one sounds like a gouging plan by the dealer. the shaft can twist but i have had a drivetrain shop fix mine before for around a 100 bucks. i would check around before trusting the dealer
Old Mar 6, 2010 | 03:38 PM
txarrowhunter's Avatar
Well whats their ujoints worth for part and labor?? probably smarter for a reason, if its going to cost you $200 then i see why they would say its smarter.
Old Mar 6, 2010 | 04:11 PM
Are you sure it's the u-joint that is cracked? If they want you to replace the driveshaft it sounds like the yoke is cracked.
Old Mar 6, 2010 | 04:13 PM
mitternocht's Avatar
I assume you mean rear driveshaft? If you have a 1-piece driveshaft, then it is 4 bolts out, pull the old shaft, slip the new one in, 4 bolts on and you are done. Not sure what is involved with a 2-piece shaft.
If you have the u-joint replaced there is more labor involved, which will need to be added to whatever the u-joint itself costs….plus might as well do the other(s) while it is out.
If you do go with the new shaft, make sure they give your old shaft back so you can rebuild it for next time you need a U-joint.
Old Mar 6, 2010 | 04:16 PM
Bark's Avatar
I dont know anything about it but some recent posts seem like that might not be a bad price esp from the dealer.
https://www.dieseltruckresource.com/...ht=drive+shaft
Old Mar 7, 2010 | 01:13 PM
thanks guys, what should it cost to fix a U joint?
Old Mar 7, 2010 | 08:07 PM
I don’t know man, maybe $150? Anything over $200 is probably too steep.
Old Mar 8, 2010 | 12:27 AM
i fixed the one on my RDS for $80 plus my time took me about 45 minutes but i had done it before twice so experience helped me.
Old Mar 8, 2010 | 08:27 AM
rich's Avatar
yea i paid about 80 for my last u joint
Old Mar 8, 2010 | 11:47 AM
justme-'s Avatar
I pulled the shaft myself (front) and had a shop that specializes in shafts and axles do it- both joints and the ball/socket thingy for $150! US made joints too.
Old Mar 8, 2010 | 03:00 PM
I am getting the U joint replaced for 100$ tomorrow, thanks for all yall's help
Old Mar 9, 2010 | 01:41 PM
Busboy's Avatar
I changed both rears on my kids truck on the weekend he said they were $18 a piece.They were Chinese though.
Old Mar 10, 2010 | 09:25 PM
Jeff in TD's Avatar
I was quoted $200 I think, at a tire shop, but their torch was out of service.
I bought an American made greaseable one for $40 and it wasn't too bad to install.
Here's a cheezy little vid of the process.
klx650a2
Apr 20, 2009 05:25 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
