Control module gone bad?
Ok guys get this:
turn key on, all lights come on, sounds normal. As soon as the ABS light goes off, all dash lights come on. Headlight switch is OFF but ALL gauges are lit up. Headlights don't work...nor do the flashers....nor do the brake lights....only the 3rd brake light works. outside temp gauge reads "--" truck starts fine and runs fine. infact it can spin all 4 wheels. [laugh] but no headlights or brake lights.....or thermometer. |
BCM failure is the best guess i have.....any other suggestions?
now truck will only run for a few seconds then dies.
so much for dynoing tommorrow [tapdshut] |
i would say from my limited experience with these issues that you have a controller issue of some kind.
tipm taking a dump ? :(
Originally Posted by Bob Wagner
(Post 1400092)
now i have 2 codes too... p0602 ECM Fueling Calibration Error/ECM Internal fault p2509 P2509-PCM/ECM power input signal intermitent back in December the cruise control would quit working randomly...but other times work then SERV 4wd would occassionally come on. Dealer pulled codes....say 2wd, 4hi, and 4low circuits open. last friday it was eating starter relays.... wednesday lights would come on and off randomly yesterday all dash lights come on with no other lights today it only runs for 3 seconds then dies. HELP. gooseneck will be here in the morning to load my truck up. its gonna ride a gooseneck trailer to the dyno event :( |
how about unhooking the batteries for awhile? since most things are controlled by module nowadays, it may be something corrupt and a memory clear might help. just a thought.
Originally Posted by dodgezilla04
(Post 1400149)
sorry pal, had to check.
(Post 1400186)
dealer says what Bob said.... $650 module |
Originally Posted by 973604x4
(Post 1399374)
That Sucks Sorry to hear that phil.
If you think it's the main ECM, check your aftermarket sources before you go to the dealer. I've purchesed 1st gen ECM's from AutoZone and AdvanceAuto.
(Post 1401439)
Bullydog was stumped when i called them....but ofcourse they would be. [tapdshut] main ECM is fine, i can still retrieve codes from it....even load and unload bullydog. theres just communication errors between the ECM and something else. dealer said what Bob said....tipm |
You have a ground issue. Or should I say a lack of ground issue...[laugh]
