Commander install ?s
Old Jun 16, 2007 | 08:17 PM
Big T's Avatar
On My truck 2006 it says to test the ECT wires bur I do not have a Volt meter but it also says conect it to pin B as labeled. Can I just tap B wire or should I get a meter.
Also on the ground in the cab what bolt are you grounding too.
And the Fuse line not sure how to atach it to the fuse. Do I go over the body with the fuze prongs going on each side??
If anybody has any pics I would apreciate it.
The good thing is I moded the air box today and pulled the baffles out!!
Old Jun 16, 2007 | 09:01 PM
mav828's Avatar
The ECT tap is to the pink wire
I put the ground to a bolt on the front cab side wall
the fuse tap goes over the #28 fuse leg and you replace it
Old Jun 16, 2007 | 09:15 PM
Big T's Avatar
Well I dont have a pink wire is b the right one? and also withe fuse I still not sure how to atach do I put the wire around the fuse then install
Old Jun 16, 2007 | 10:05 PM
Big T's Avatar
Thanks for the help I got it all done just waiting to tap the Manifold for the egt.
stock03
Nov 9, 2006 11:27 PM
jaredb900rr
38
Nov 6, 2006 12:09 PM
edtyler
Oct 12, 2006 03:09 AM
skydiver41
Sep 1, 2006 11:53 PM
twlunn
Aug 17, 2006 10:17 AM
