Clutch disengage issue, Help
Old Feb 19, 2008 | 10:48 AM
CTD_Neil's Avatar
This morning as I backed up, the clutch engaged right away and then would barely disengage. Same thing when pulling into the parking spot at work. I'm thinking it's the master or slave? what else could it be? Thanks
Old Feb 19, 2008 | 09:23 PM
DZLPWR's Avatar
That is prob you prob. Mine did the same thing, went into parking spot and would not disengage Untill it completely stopped working a few days later with a boat in tow . I bought the entire slave/master cyl combo already filled w/ fluid and it was pretty easy to put on in about 30 min. A word of caution tho, the slave cyl has two pins that connect the press. line leading into the cyl, SAFTEY WIRE THEM!! Just for good measure...... Dont ask me how i know They just might fall out when you least expect it a couple weeks after install
Old Feb 19, 2008 | 10:01 PM
GAmes's Avatar
When mine failed I was able to "pump"it up. If you can't do that you might have something else wrong. The best price was from WWW.Mopar4less.com
If you call them be sure to ask for "internet parts"
lgp9999
14
Feb 26, 2010 07:40 AM
Arsenal
Aug 10, 2009 12:17 AM
Backwoods Bumpers
Nov 20, 2007 08:01 AM
badmrb
Jan 3, 2007 07:18 PM
B.A.Ram
May 25, 2005 01:06 PM
