Clearance lights wont work!!!
Old Nov 21, 2005 | 03:53 PM
fireparm84's Avatar
I need help! I have a 1998 dodge 2500 4x4 with the diesel. My clearance lights wont work. I looked in fuse panels and found nothing burned out. I pulled cover off A post and found a red wire that had stripped end coming out of headliner. Any ideas what this goes too? Truck inspection due this month so I have to get them fixed ASAP. Thank you
Old Nov 21, 2005 | 04:45 PM
Andy505's Avatar
Pull down your headliner and see what it the wire was pulled out of and rewire it, your lights should work then.
Old Nov 21, 2005 | 06:14 PM
blackdiesel's Avatar
Registered
pull out the headlight switch the cl. lights just have a scotch lock tap on the parklight wire and they are known to not make connection this is where your problem will be I bet
ehammett
13
Dec 30, 2008 05:20 PM
robert78.5
Jan 20, 2008 10:18 PM
Ramcam
Apr 7, 2007 03:43 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
