camshaft timing marks
Old Jul 27, 2003 | 06:10 PM
thumper 549's Avatar
has any one else found thir shaft dots not quite lined up with the crank shft dot on thir 24 valve eng.?<br> I can't fathom this is how it is supposed to be ,off two teeth is it?????<br> help help help help whats the ans to this???
Old Jul 27, 2003 | 06:21 PM
Mexstan's Avatar
Re:camshaft timing marks
Try rotating the camshaft one more full turn and then see if it lines up. Also make sure that you are truly looking at timing marks and not something else. Don't know on your model but am guessing that the timing marks are either a drilled dot or a stamped line. Be careful if it is a paint mark as that can be misleading.
Old Jul 27, 2003 | 08:34 PM
Your perfectly right , I was looing at the fuel pump marks. :-[
Brutalowner
May 9, 2009 04:20 PM
knowntoram
Oct 20, 2007 09:55 PM
G1625S
Mar 18, 2005 06:41 PM
Den
Mar 16, 2005 05:56 PM
