burning wire
Old Mar 4, 2007 | 07:24 PM
kinser5mfan's Avatar
burning wire
i have a wire burning on my truck
i noticed a smell of diesel but couldn't find it then i noticed that on top of the fuel filter canister there are two wires going into a black rubber peice. and the red wire is smokeing
what is this and how do i fix it thanks in advance kirby
Old Mar 4, 2007 | 08:08 PM
johnrawdon's Avatar
Sounds like you are describing the fuel heater that is in the fuel filter canister and that the integral fuel temperature sensor that tells the fuel heater when to cycle is stuck in the on position. Just a guess but I would check that out. Also the fuse in that circuit might be the wrong size?
Old Mar 4, 2007 | 10:17 PM
so i obviosly need that heater but where is this " integral fuel temp sensor" located and are these things something that can be done at home ?
Old Mar 7, 2007 | 07:09 PM
johnrawdon's Avatar
Well I am using my haynes manual for this info. I have not changed one but it doesn't look to bad according to the manual. I only know about this because I am having problems and have been reading this section of the manual. I have the 1994-2001 Haynes repair manual, picked it up at parts store. The fuel temp sensor is located in the header part of the fuel filter. You would have to remove filter and then remove the header part of it from the truck and the sensor is in the top part. I am sure others can help more. I am sorry to take so long to get back to you but I was out of town and had no computer. John
duallydave
Jan 22, 2009 04:50 PM
Rollin Smoke
Oct 24, 2006 10:24 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
