Broken Front Axle U-joint
Old Jul 17, 2007 | 01:28 PM
K RUSSO's Avatar
Broken Front Axle U-joint AAM 2003
Need Some Info On Disassmbaly The Wheel Hub Wont Come Apart So I Can Get To The U-joint
Old Jul 17, 2007 | 03:03 PM
dieselrob's Avatar
Loosen the 4 bolts holding the hub on. Leave the bolts in a few threads, put the socket on one and an extention, have someone there to help, start the truck and turn the wheel so the extention hits the axletube and is pushing on it. Turn the wheel with a little force and it should pop the hub right out.
Old Jul 18, 2007 | 12:11 PM
smokeyram's Avatar
While you are in there, I would recomend putting in greasable ball joints.
Just getting the axel out is enough of a job, one more step and you will have one less thing to worry about.
mbmrang
Aug 18, 2009 11:31 AM
rodriguez7
Dec 29, 2008 12:06 PM
stealman1
May 6, 2008 08:05 AM
CG98x
Feb 12, 2007 04:49 PM
figure_9_pro
Jan 31, 2003 11:01 PM
