brakes get hard and loses steering...
Old Dec 22, 2008 | 02:25 AM
slubik's Avatar
Help!! i just did all new tie rods track bar gearbox and tires now something else is wrong... when i went to get on the hiway i pushed on the brakes and went to turn to the on ramp and all of a sudden had a hard pedal and no steering!!! what do i need what do i check? truck is a 2001 4x4 auto ex cab short bed
Old Dec 22, 2008 | 07:48 AM
MoNStrRIg's Avatar
Check your power steering pump, it powers both the steering and brakes....
Old Dec 22, 2008 | 10:44 AM
slubik's Avatar
the pump was low and i added fluid. but its still the same do i need to bleed it and how would i do that?
Old Dec 22, 2008 | 11:42 AM
cameroneod's Avatar
Any leaks? Start it up and have someone else crank on the wheel. Crack open the line coming from the pump. No fluid=no power steering pump.
Old Feb 10, 2009 | 01:04 PM
ratman46's Avatar
had same problem. something got in the pump from the box u replaced change out the pump again but run 4 quarts of tranny fluid to clean out any debrea still left inthe box. start engine leave low side hose in pail to catch fluid. reatach hose .fill pump .turn steering all th eway left then right several times to bleed good luck
Old Feb 10, 2009 | 05:51 PM
Doj Dewd's Avatar
don't replace your pump yet. this problem is notorious in cold weather. flush or bleed all the fluid from the system and replace with synthetic.
the reason for this is that the conventional fluid becomes VERY viscous when cold and creates too much pressure - and gushes out of the weak spot in the system - usually the cap.
i was advised at one time to replace the pump, tried the sythetic swap and haven't had a problem ever again.
Old Feb 11, 2009 | 10:20 AM
infidel's Avatar
There is a filter screen in the pump that can plug up also, easy to clean.
Dargo
Jan 12, 2018 07:45 PM
Dhorn33
37
Oct 22, 2008 06:21 PM
BIGBEN
Jan 14, 2008 08:53 PM
Crimedog
Nov 7, 2006 01:52 AM
Bob Blockland
May 15, 2005 04:33 PM
