Brake Job Woes
Old Apr 25, 2005 | 11:55 PM
cville6's Avatar
Brake Job Woes
Just finished a complete brake job. At 108,000 miles it was time for a good going over. Replaced pads, shoes, calipers, and wheel cylinders. Turned drums and rotors. After reassembling everything and bleeding out the line everything is great; stops better than it ever has since I've owned the truck. But........ now the "ABS" and "BRAKE" light on the dash are on. I know everything is working ok from the way it stops, but the dash looks like a Christmas tree. How do you reset these lights or systems?????
Old Apr 26, 2005 | 10:18 AM
infidel's Avatar
Try disconnecting the batteries for an hour or so.
Old Apr 26, 2005 | 09:15 PM
WildBill's Avatar
Fluid level sensor in reservoir stuck down?
Old Apr 28, 2005 | 06:26 PM
ludwick_j's Avatar
It could be the rear wheel speed sensor on top of the rear diff. Mine came on about a month ago. It turned out to be a fuse. A lot cheaper than the speed sensor. Is your speedometer working properly?
Old Apr 29, 2005 | 12:06 AM
Hemi Cat's Avatar
Most likely a speed sensor. 4 wheel abs or rabs?If 4 wh abs you could have disturbed a front wheel sensor or wire. Air in the abs unit will set the lights too.
Old Apr 30, 2005 | 11:55 PM
cville6's Avatar
Thanks for the suggestions! As it turns out I didn't have to do anything. I wasn't going to deal with the dash lights after finishing the brake job late at night. Parked the truck planning to to work on it the next day. Next evening I fired it up to put it in the garage and all the lights went out a normal. Great brakes and no warning light. Life is good!
Prodart440
Apr 27, 2008 01:22 PM
Eskimo
Aug 8, 2006 03:05 PM
TxDiesel007
Aug 23, 2005 10:20 PM
mx261
Apr 14, 2005 03:58 PM
