Ball joint install - starting crooked...
Old Jun 7, 2011 | 07:06 AM
ShouldBFishin's Avatar
Any tips on pressing in ball joints “straight” and straitening one that started crooked?
I rented a ball joint press with some 4WD adapters, got an upper and a lower out. After prepping the hole with emery cloth and greasing the new ball joint I started pressing the new upper back in and it’s a little crooked . It’s not in very far, but I’m concerned that if I try to push it back out I might trash it and if I keep going it might be really difficult to press in all the way.
Any help would be greatly appreciated.
Old Jun 7, 2011 | 07:08 AM
Purplezr2's Avatar
Press if back out and straighten it when it goes in the next time is what I would do, if its alittle off it should self straighten.
Old Jun 7, 2011 | 07:10 AM
vp dually's Avatar
Mine started to tip also. Dont let it push down to far when it starts to tip. Tap it with a hammer. DONT beat on it. Take your time. Make sure the tool is centered . Also what he said ^ if it a little off it will shore up.
Old Jun 7, 2011 | 08:42 AM
Thanks guys...
I did get it to straighten out - it wasn't in very far so I took out the zerk, holding a pry bar on the high edge and tapped on it with a 4 lb hammer until it was straight.
I noticed that the cup was sitting at a little angle, so I shimmed it a little with an 1/8" strip of metal. Looking pretty good now.
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
