Back up Lights
Old Feb 26, 2007 | 09:24 PM
Tracy's Avatar
Question Back up Lights
I have a 2001 quad diesel, my back up lights wont turn off even with the key out of the ignition.
Old Feb 26, 2007 | 09:55 PM
AggieJustin's Avatar
Sounds like a short in the trailer wiring harness/plug.
If you still have the factory 7 pin plug on the receiver hitch, check in the end and make sure you don't have anything in there that might be causing a connection. But the more likely culprit is worn through wires in the harness feeding the plug that are allowing voltage from the +12V circuit to feed into the backup light circuit.
Old Feb 27, 2007 | 05:44 AM
handymantim's Avatar
I had a similar problem with my trailer wiring. My passenger side brake light was stuck on and it was caused by a short in the trailer wiring.
03CTDCO
Mar 6, 2010 10:48 PM
getrdun
Nov 26, 2008 11:46 AM
JoshPeters
Apr 3, 2005 08:13 AM
CHarlan
Aug 6, 2003 08:40 PM
