Anyone have this problem
Old Jun 14, 2007 | 08:25 PM
06dodge's Avatar
My power steering keeps locking up on me, ill go from rev to drive and it will lock up, it did it once right after i got it but i took it in and they replaced the pump and said that there was a tooth broken, now with my edge and high ram im kinda not wanting to take it back unless something is really wrong.
anyone else have this problem!!
Old Jun 16, 2007 | 10:36 PM
RCW's Avatar
RCW
Remove the Edge and take it to the dealer. When the first pump failed it nearly always will puke metal into the actuator valve in the steering box. That will cause the system to start randomly locking up when the metal bridges two valve orifices and keeps them from actuating, and means that both the new pump and the steering box will need replacement. The hoses and cooler must also be flushed before installation of the new components.
This is a very serious situation and if they give you any hesitancy of doing it right you need to call your State's consumer affairs office and call and write to Dodge's customer service folks directly.
Do not drive the truck in this condition. This is a very dangerous situation and can actually cause the power steering to go full power in one lock or the other (direction) unexpectedly, wrench the wheel out of your hand, and could lead to a serious accident.
Old Jun 17, 2007 | 06:34 AM
06dodge's Avatar
ok i was gonna take it in and get it looked at but i have one question----when removing the edge, what do i do with the EGT hole in the manifold??
do i just leave it in there and remove everything else or do i plug it with something?? im not sure how the dealer is about performance things so im not sure what to do, or am i just screwed???
Old Jun 17, 2007 | 07:25 AM
belgianmagic's Avatar
a pyrometer is NOT a performance thing
you tow ALOT and want to watch your EGT's
thats all
Old Jun 17, 2007 | 11:49 PM
06dodge's Avatar
so what do i say about not having a gauge? since it is hooked up to my edge?
sorry about all the stupid questions im still kinda new to the diesel thing
Old Jun 18, 2007 | 06:15 AM
donhov's Avatar
Tell them that your gauge failed and it has been sent in for repair. Or any other plausable thing you can think of. Shouldn't be an issue. Just be sure to remove all velcro and anyother traces of your Edge.
Old Jul 2, 2007 | 02:02 AM
06dodge's Avatar
ok i took it in to dodge and they had it done the 2 days later, they told me that it was gonna be till the 11th before they could even look at it, it turned out to be the steering gear(for the second time).
brianpgriset
Jul 7, 2013 08:26 PM
turbov6joe
18
Dec 4, 2008 08:15 PM
bigfish5
Mar 10, 2007 12:11 AM
GotCummins?
22
Jun 15, 2004 10:31 AM
