Any electrical system guru's? Need help
Old Nov 9, 2002 | 02:07 PM
Jbolt001's Avatar
I "believe" I know where my fault light is coming from but I do not know how to properly diagnose it. With the (+) pos terminal disconnected from the battery and all the aux/acc wires disconnected from the (+)pos bat cable lug I am getting current from the large black wire that I'm pretty sure goes to the alternator. I disconnected what I think is the same wire at the alternator. See pics below
Old Nov 9, 2002 | 02:08 PM
Jbolt001's Avatar
Re:Any electrical system guru's? Need help
Same wire (?) at the alternator side.
Old Nov 9, 2002 | 02:12 PM
Jbolt001's Avatar
If I hook a teast lead to the wire to the alternator bypassing the long wire that goes back to the battery I get no current. This leads me to believe there is a short or?? in the wire or some part connected to that wire the goes between the battery and the alternator. What do I check next?
Old Nov 9, 2002 | 03:55 PM
Alan_Reagan's Avatar
Your "what's this" in the picture are the grid heater connections if I'm not mistaken here. I still don't understand what the problem is. Is there a post somewhere else describing your problem. I'll look and see.
Old Nov 11, 2002 | 06:10 AM
Smokee's Avatar
Jbolt:<br>I am not sure what the problem is either. However, from what I understand from your posting, when you jumper the wire from battery to alternator, there should be no current. if there were a voltage reading, you would have an open circuit.(potential defference)<br><br>I may have misread your post.<br>george
Old Nov 11, 2002 | 07:35 AM
Jbolt001's Avatar
Thanks everyone. It was a problem in the alternator.
manureman
Aug 28, 2009 10:16 PM
dizzel
Jul 31, 2009 07:54 PM
Luvnacumns
Apr 8, 2007 12:39 AM
JW3
Jun 18, 2006 09:25 PM
fitzer
Aug 8, 2004 06:55 AM
