ABS/Brake light turning on
My 98.5 24v auto 4X4 QC (4WABS) has given me re-ocurring problems with the ABS and Brake light turning on. This is like the third time this happens to me. The dealer fixes it (no idea what they did), and then it reocurred again. Has anyone had the same problem as frequent as me. Any idea what I should tell the dealer, or how I should fix it once and for all. My ABS is not working, and it is really annoying me. Any help would be much appreciated. Thx.
Re:ABS/Brake light turning on
When I had trouble with my ABS and brake light, it was a bad speed sensor, located in the rear differential. Had it replaced, no more problems. When the lights are on, brakes work normally, but, you're right, the ABS system doesn't operate. I hope that this helps.<br><br>DeWain
I purchased my truck two weeks ago with the Brake and ABS lights on. I have not had time to figure out what is wrong so I am very curious to here what you find. Looks like this is a common problem from the amounts of posts on the topic.
I've got 3 trucks total, and it's happened to all of them at one time or another. Twice from plowing snow, and snagging the wires that connect to the sensors in the front wheels. Check that first, if there's a cut, splice it. Also, if you do alot of off-roading, check to make sure those wires are tight and not getting bound up and/or pulled on. If they get pulled or snagged too hard, it can break the sensor. On all 3 of my trucks, it was caused by those wires.
My '99 just started yesterday coming home from work, the ABS/Brake lights came on and then I noticed my speedometer drop to 0 at 25 MPH! Above 25MPH everything seems ok, could the sensor be the same problem on my truck, and where is it located on my 2500 4x4?<br><br>Thanks, Michael
[quote author=jdeereboy link=board=13;threadid=13717;start=0#141139 date=1053651690]<br>The rear axle sensor is only an ABS sensor and will not affect the speedometer. <br>[/quote]<br><br>Sorry to disagree with you, but you are wrong. The abs light comes on and the speedo only starts registering at 15 to 25.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
mr T
Feb 24, 2007 06:42 AM
