'97 2500 Diesel Intermitting Start Problem
I took my truck into the dealer. I explained the trunk won't start sometimes, unless I jiggle the column shift in either parking or neutral. They couldn't find anything and suggested replacing the starter at $1600. So I am now living with this problem. It seems worst on cold days and when the gas tank is low. There isn't any sound other than a click sometimes. No cranking, nothing. Any ideas? Thanks.
Re: '97 2500 Diesel Intermitting Start Problem
Wow, sorry you didn't stumble across us before you visited the dealer.
If jiggling the shifter seems to fix it, then switch in the transmission that tells it when it's in park or neutral would be the first thing I'd check.
phox
Well untill you mentioned the low fuel part I was thinking it was the neutral safety switch but the low fuel I dont understand? $1600 for a starter? Are they pulling the cab to install it? You need to see a different dealer. Check the connections on the starter and batts something may be loose?
Viv,
Like the others I immediately thought neutral switch, the low fuel doesn't seem to fit in anywhere
but the "click" caught my attention.
Might want to look at starter contacts.
http://www.fostertruck.com/dodge/
but the "click" caught my attention.Might want to look at starter contacts.
$1600 is just freakin' robbery. I'd bet starter contacts too. You might want to get at it pretty quick as that click you hear is the shutdown solenoid lifting up. If you hold the key in the start position too long the solenoid gets hot and you'll burn it out. It's a couple $100 to replace for sure. The starter contact fix is pretty easy if you're handy at all.
Donmacky
Feb 1, 2014 06:07 PM
Hunky Dory
May 13, 2013 08:09 PM
CoolumConst
Oct 11, 2008 10:00 PM
