94 lift pump primer
Old Jan 30, 2005 | 08:05 PM
overkill12v's Avatar
94 lift pump primer
Does any one know if the plastic primer assy. is available as a separate unit from the lift pump it self.Had a small leak coming from the plunger area ,tried to remove it without taking liftpump assy. from engine ended up breaking it.Seached a couple of parts sites they list the pump but don't list the primer.
Old Jan 31, 2005 | 09:14 AM
infidel's Avatar
Only part of the lift pump that is available separately is the o-ring that seals the plunger. Sorry if my previous advice contributed to your breaking it..
Old Jan 31, 2005 | 05:55 PM
Thumbs up
no big deal,I tried to cheat by not removing starter and liftpump assy. from truck.I was doing it outside laying on the ground in the snow,and well i just should have not tried to take a short -cut.Stopped by local truck garage,they do lots of B-series equipped UPS trucks,they had a low miles, used lift-pump assy.they let me have it NC.(sweet) I only wanted the diaphram assy to repair mine but they hooked me up. live and learn,Appreciate your help anyhow.JD
Old Feb 2, 2005 | 07:49 PM
Went to reinstall the lift pump Mon. and discovered the fuel temp. sensor was all fallin' apart .the sensor is not available sepparately from the fuel heater had to buy a new assy. from dodge 180.00 ouch. talking to diesel mech. told me it's a fairly common deal.so after 1day and 3 nights of monkeyin' around in the snow and cold,my rig is back!
Old Feb 3, 2005 | 09:15 AM
infidel's Avatar
Should of went to Cummins, the assembly is $38
Ilikebikes
Sep 19, 2006 05:54 PM
CZSteve
May 18, 2006 10:58 AM
sjessop
Jun 4, 2004 12:29 PM
yrusoslow2
Jul 1, 2003 02:18 PM
