91 ran out of fuel, bleed system, Still pushing out air. ***!!
Old Mar 29, 2009 | 01:31 PM
  #31
Deadbunny's Avatar
Originally Posted by 2stroke
to really make sure run that clear tube to a fuel can, see if that helps.
I have about 2 feet of clear hose going into the LP. the line runs up to the cab where I can SEE the fuel moving through the line as I turn the engine over.
Old Mar 29, 2009 | 01:56 PM
  #32
jckdann7's Avatar
Mine did sort of the same thing, I think it turned out to be the fuel heater. I did have a bad lift pump but when I got that changed I had good pressure to the filter (8-9psi) but I bled the injectors 1000 times. 1 at a time, 3 at a time , every way you could think of. I tighten down the filter, I didn't have the gasket for the heater so I didn't want to take it off and not able to use the old one. I finally hooked up the powerstroke up to it with good jumper cables to keep it cranking, I was gonna blow it up or start it. cranked it for 15-20 sec and it started.
Old Mar 29, 2009 | 08:45 PM
  #33
1985cucv's Avatar
could you have loosened the filter housing? this happened to me and it was running rough and leaking fuel
Old Mar 29, 2009 | 09:55 PM
  #34
Deadbunny's Avatar
I thought of the filter housing being the problem to. Im still not sure what the thing that is in between the filter and the head is. However non of it is leaking and being under 5lbs or pressure, Iv ruled it out.
Old Mar 29, 2009 | 10:17 PM
  #35
jckdann7's Avatar
between the filter and the block is the heater. Mine didn't leak at least at idle, but with the motor off, i could pump the lift pump and hear the leak. I tighten it back down and it works now. I still have a leak but now I think its clamp behind the **** motor that i cant get tight.
RJC
May 24, 2010 11:18 AM
RJC
Southern Pride
15
Mar 12, 2010 12:42 PM
Bad Ramer Jamer
13
Jan 12, 2008 05:38 AM
aicomp
Nov 6, 2006 01:03 PM
