47RE automatic transmission
Old Aug 16, 2003 | 08:09 PM
Ghostrider's Avatar
Need some help with my automatic transmission. Everything is stock, I have a 2002 Dodge Quad Cab 4WD, that has no first gear anymore. Starts out in second gear, all other gears work fine including overdrive. Even when pulled down into first gear with gear selector, it still doesn't work. Vehicle has 60000 miles. Any suggestions would be greatly appreciated.
Thanks- Ghostrider
Old Aug 16, 2003 | 09:21 PM
AZGEARPRO's Avatar
Re:47RE automatic transmission
try adjusting your kick down cable, when is the last time you dropped your pan could have a pluged valve
Old Aug 16, 2003 | 09:22 PM
AZGEARPRO's Avatar
does your reverse gear work because they are the same clutch pack being used
Chemical
29
Jul 6, 2025 12:59 PM
GaveUpOnTV
Mar 15, 2014 12:49 PM
bullredd
Jan 21, 2010 11:37 PM
Munchies
Oct 19, 2006 06:09 AM
firefighter2000
Mar 7, 2003 07:57 PM
