4 liters in 100km
Old Apr 13, 2011 | 11:24 PM
fargoranch's Avatar
4 liters in 100km
05 Losing oil fast, I can't pin point the leak. Thought it was rear main, but no oil inside tranny inspection cover. Tranny oil cooler is covered in oil. So just guessing it might be the valve cover. What else is there behind the fuelfilter that might leak.
Old Apr 14, 2011 | 08:57 AM
jhenson's Avatar
No oil in the tranny inspection area should rule out the cam seal. I accidentally nicked my valve cover gasket the last time I reset the valves and it did leak quite a bit of oil. You might check that if you've had the cover off recently. Other than that I can't really help you out much. Hope you get it located and fixed. Keep us posted.
Old Apr 14, 2011 | 02:43 PM
fargoranch's Avatar
Ordered a new gasket from cummins, so I can try that. Had it off about a year ago when I did the injectors. The gasket doesn't look that bad though, not for the amount of oil.
Old Apr 14, 2011 | 08:46 PM
jhenson's Avatar
Are your valve cover bolts tight? That too would cause an oil leak but that much in such a short distance kinda has me stumped. I'd clean the engine very thoroughly and start from there. That kind of a leak should be visible if the engine is clean.
Old Apr 15, 2011 | 12:12 AM
DieselLady's Avatar
There is an oil feed and drain from the turbo as well. Could be spraying from there!
Old Apr 15, 2011 | 01:47 AM
fargoranch's Avatar
going to replace the gasket and clean her up and see what we see.
dangina
Nov 7, 2010 03:25 AM
klx650a2
40
Nov 11, 2009 04:45 PM
vj_M
Jun 18, 2007 01:41 AM
AlbertaBear
Jul 20, 2006 11:46 PM
Farmer05
Jun 15, 2004 11:30 AM
