4 codes and not shifting ???
Old Oct 18, 2008 | 10:46 PM
oldblues's Avatar
Question 4 codes and not shifting ???
hi
my trans has stoped shifting for the most part .
1998 12v 47re truck in my signature
starts out in wrong gear and does not go to lockup or o.d.
po743
p1389
p0753
p1765
i have installed a mystery switch recently and wonder if this has caused a problem someware ?
i left the relay in and installed a 33 o h m resistor to ground .
read it here someware ?
was working perfectly for a few days and suddenly feels like a limp mode of some sort ?
i am fairely certian it is an electrical prob as trans did shift perfect with no sliping till last night , no funney noises ect .
what is my most likely prob ?
Old Oct 18, 2008 | 11:18 PM
dozer12216's Avatar
Undo mystery switch. Reinspect your wiring job.
Old Oct 19, 2008 | 10:29 PM
oldblues's Avatar
hi
why undo mystery switch ?
it is simply a way to ground the wire to cause convertor to lock up .
just turning it off puts the system back to stock !
who has done there switch the same as mine ?
i d not think the pcm is sending he signal o lock convertor ?
all connections are good which puts it in stock mode with switch off !
what are the codes telling me is most likely prob ???
Old Oct 20, 2008 | 05:30 AM
P.J's Avatar
P.J
Could be governor pressure solenoid. I had one go on my 2001, truck started out in 2nd gear. It would run fine after that, even down shift, but refused to start in 1st.
Old Oct 20, 2008 | 11:07 PM
oldblues's Avatar
hi
well i have corrected the prob for now by simply eraseing the codes ,not sure what caused them yet , no codes after a short drive ?
trany back to working perfect for now .
i have installed a preasure switch to disingauge the lock up even when switch is on , so if you forget to turn it off when slowing down below 28 mph it automaticaly disingauges lock up !
no more bucking when coming to a stop , and if you have to slow down suddenly and dont have time to switch it off it is automaticly done for you!
so i can switch it on at a stop and it automaticaly locks at 28 mph , me like !!
when it warms up a bit here i am going to drop it to 24 mph and test .
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Brendan
Oct 17, 2007 11:12 AM
mbenedict
Jul 21, 2007 09:19 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
