4.7 V-8 cam sensor
Book gives .5 hours. It's located on the front/top of the right cylinder head, just below the valve cover according to the picture. Book says it's easier to remove/install from under the vehicle. Just a matter of unplugging, unbolting, carefully pry out, clean out the hole, lube the O-ring and slide in the new sensor. Torque for the mounting bolt is 106in lbs.
HTH
John
HTH
John
etn550
Apr 1, 2010 12:12 PM
Gabe32
16
Feb 22, 2007 06:37 PM
