205,000 miles; bad shake on highway. Please reply
Old May 26, 2003 | 09:14 PM
antknee's Avatar
I have a 97 dodge Ram cummins turbo 12 valve 2500 diesel 4X4 SLT.<br><br>Between 180,000 miles and present I have had a bad shake at 55 MPH and above on Highway. I had the whole front end redone (axle U-joints, ball joints, trac bar,steering stableizer, ETC.) I also went through 3 sets of tires!!! Tires were re-balanced 2 times each set!! 245 75 R16's. I also had engine mounts checked. New shocks also.<br><br>WHy is this happening. Up until 180,000 miles the truck drove so smooth at 80 MPH!!!! and now it's shaking. I know it has miles on it, but everything is able to be fixed.<br><br><br>Any tips?<br><br>P.S. <br><br>Recently the trucks front end started to bounce up and down when the brakes are hit from time to time. Like the shocks are bouncing.<br><br>Is it possible the shocks springs are messed up and I can't see the problem?
Old May 27, 2003 | 07:44 AM
bulabula's Avatar
Re:205,000 miles; bad shake on highway. Please reply
It appears that the vib's are speed related and not rpm related. It also sounds like you're worked/replaced every bit of rotating mass except for the brakes/rotors; and driveshaft.<br><br>What shape are the brakes and rotors in?<br><br>I see you've balanced the tires twice now, but could you find someone to swap a set of known good tires on your truck to eliminate the most probable cause? How many miles on this set of tires?
Old May 27, 2003 | 03:17 PM
Smokee's Avatar
Just a guess, but do you perhaps have a sticky caliper?
Old May 27, 2003 | 07:17 PM
jdeereboy's Avatar
I had a '84 W350 4WD that had a terrible front end shake that would start all of a sudden and would not go away until I would slow the truck down to 20 MPH or so. Friend called it a &quot;Death Wobble&quot;. I tried aligning, balancing, new rotors, drums, and U-joints. I untimately figured out that it was due to the wheels and tires being out of round. I figured this out by jacking the truck up and running it in 4WD and in drive. I a piece of chalk against a stool to mark the high spots of the tires as they were spinning. Anyway, that was what was causing the problem on one of my trucks. Easy to check. <br><br>If your rotors are suspect I would suggest just replacing them since they are so inexpensive. I just picked up new ones for my '99 for only $45 each at Advance Auto.
Old May 27, 2003 | 07:44 PM
antknee's Avatar
thanks!!!<br><br>I'll check out the caliper.
Old May 27, 2003 | 07:45 PM
antknee's Avatar
I have a friend that could let me try out his tires. Good idea!!<br><br><br>Also, my brakes and rotors are in good shape. I use ceramix brake pads and they last forever!!! The rotors were checked and they are smooth.
Old May 27, 2003 | 09:50 PM
Sootblower's Avatar
While you have tires off ground grab tire and check for bearing play. Should be 2 to 10 thousandths I believe. Mine had the death wobble when it was about 80 thou. I had to tighten my bearing more than the book said (I backed off 30 degrees rather than 120 that book said). The cones seem to get a steeper taper with more milege.
Old May 27, 2003 | 11:33 PM
antknee's Avatar
I'll try it this weekend. <br><br>This weekend projects: check caliper, tires, and bearings!!!<br><br> <br><br><br>
Old May 28, 2003 | 01:45 AM
dersequim's Avatar
When you finish ALL THAT could you drop over and install a set of front shocks on MINE!! :
Old May 28, 2003 | 03:37 AM
antknee's Avatar
I charge $1000/Hour<br><br>I'm 24 and want to retire at 27.<br><br><br>Ha Ha<br><br>
Old May 28, 2003 | 08:43 AM
Redleg's Avatar
[quote author=Sootblower link=board=13;threadid=15161;start=0#142820 date=1054090234]<br>While you have tires off ground grab tire and check for bearing play. Should be 2 to 10 thousandths I believe. Mine had the death wobble when it was about 80 thou. I had to tighten my bearing more than the book said (I backed off 30 degrees rather than 120 that book said). The cones seem to get a steeper taper with more milege. <br>[/quote]<br>Good Point!!<br>When I repacked my bearings, I thought there was no way the book could be right. Followed directions exactly, and there seemed to be too much slop. Tightened them a little more by feel and all is still well.
Old May 28, 2003 | 08:44 AM
Redleg's Avatar
[quote author=antknee link=board=13;threadid=15161;start=0#142916 date=1054111033]<br>I charge $1000/Hour<br><br>I'm 24 and want to retire at 27.<br><br><br>Ha Ha<br><br><br>[/quote]<br>Think you could get it all done in 10 minutes?
Old Jun 23, 2003 | 03:34 AM
antknee's Avatar
Do you mean that my rims could be out of balance? I haven't hit any curves or anything. They are the original rims.<br><br>Well, I checked and the brakes were re-done. needed it anyway. New rotors. Drive train U-joints are fine. I want to check steering damper and U-bolts on leaf springs.<br><br>Bearings are fine, tie rods are fine, and I am installing lukes link this week. <br><br>Can't figure out this wobble : (<br><br><br>The truck bouncing thing when hitting the brakes was from bad rotors, but I still have a shake at high speeds.
Old Jun 23, 2003 | 04:39 AM
LHartman's Avatar
I went through it when my track bar wore out. I still had a little slop in the front end after I replaced it and am still fighting it to this day. I changed out every worn part I could find. <br><br>Finally I looked at the steering arm that leads from the steering wheel to the gear box. There are two small u-joints on this arm. Both of mine were worn out and still need to be replaced. I'm hoping this takes some more of the slop out. I doubt this is your problem. Shot in the dark, but may help............
Old Jun 23, 2003 | 06:47 PM
claing's Avatar
I agree with bulabula, try another set of tires and wheels, a bad or out-of-round wheel will cause lots of problems or a tire with chord seperation that will cause out-of -round condition. If a shock or shocks are bad or weak just a little out-of-round or out of balance will be pretty noticible. Sound like you have covered most other bases.
