Sponsored by:
Sponsored by: CARiD
Which two stroke to use?
Old Nov 3, 2009 | 04:10 PM
madhat's Avatar
Administrator/Jarhead
I know that there are a few kinds of 2 stroke...
Non detergent, right?
Thanks...
mad
Old Nov 3, 2009 | 04:20 PM
STate's Avatar
tc-w3 two-cycle. Get mine at walmart...Super Tech, 1 gal blue jug.
Old Nov 3, 2009 | 04:42 PM
cbrahs's Avatar
how much you using per fill up?
Old Nov 3, 2009 | 04:53 PM
irocpractice's Avatar
Castor Bean oil mixed with Blendzall
Old Nov 3, 2009 | 05:00 PM
STate's Avatar
I started with one ounce per gal. Then started using it along with Power Service Diesel Kleen so I cut it back. In the summer I usually add between 16and 20 oz. per fill up. In winter I either run nothing but Power Service (white bottle) or I mix in some 2 stroke with it. I dont know if it runs quieter or not, but I like the fact its providing more lubrication to my fuel system.
Old Nov 3, 2009 | 05:19 PM
megacabdad's Avatar
Anything that is "ash less" is OK to use.
Wallyworld is probably the cheapest and easiest to find it at.
Whenever I think about it, I'll buy one of the small bottles and dump the whole thing in when I fill up.
Old Nov 3, 2009 | 07:40 PM
Oldschooldodge's Avatar
That's what I use. Says "Outboard 2-Cycle tc-w3 Engine Oil" on the jug. Been running it almost a year now without a problem.
Old Nov 3, 2009 | 07:48 PM
Blake Clark's Avatar
I run the Supertech TCW3, 16oz per fillup, every other tank. Purchased while observing the People of Wal-Mart.
Old Nov 3, 2009 | 09:02 PM
CoastalDav's Avatar
TC3 does not leave an ash or sludge after combustion. Meets EPA regs for
2 cycle engines.
Dave
Old Nov 3, 2009 | 10:23 PM
madhat's Avatar
Thanks for the info...
Old Nov 4, 2009 | 04:11 AM
HMX-1's Avatar
Yup, same stuff, same place I get mine. I use about a pint per fill up on my '06.
Kris
Old Nov 4, 2009 | 06:34 PM
Hvytrkmech's Avatar
How long have you guy's been running 2 stroke oil? I had thought of doing it, I am just worried about plugging up the cat. Do you have a noticeable difference in noise?
Old Nov 4, 2009 | 08:49 PM
rockcrawler304's Avatar
I run Supertech TCW3 from wally world also. I use 16oz per every other fill up. Sometimes every third if I forget
Old Nov 5, 2009 | 02:08 PM
supr's Avatar
I think most people feel the motor runs a bit quiter. The main cincern is the low lubricity of ULSD in 5.9 trucks (07 & earlier). I think a lot of people have run this a long time.
There is some controvery over wether Power Servce,silver or white, has any lubrication at all, even though it says it does.
I think they are both worth unning in your fuel.
Old Nov 5, 2009 | 03:03 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
Who runs a cat these days?? jk.
I started using it when I was running my truck on straight Jet A. 1 oz. per gallon.
Now I just pour a quart in every now and again. at least once a month. I do not drive as much as I used to.
I can say that it has really helped my injectors, They do not act up very often at all.
