Sponsored by:
Sponsored by: CARiD
Statics Question for you Engineers
Old May 16, 2008 | 12:30 AM
svanni's Avatar
I recently mounted a psi gauge on a tapped banjo bolt. It threads onto the CP3 and torque specs say tighten to 18 ft lbs. The problem was, with the gauge in the way, I couldn't put a socket on the banjo bolt (the gauge was threaded directly into the top of the banjo).
But I could get a open-end 7/16" box wrench on the back of the gauge. And the 3/8" drive extension fit perfectly into the other end of the box wrench. It worked like a extra-long crowfoot.
I kept the box wrench and torque wrench at 90 degrees (relative to each other) and torqued to about 15 ft lbs.
Can anybody tell me what the torque was at the banjo ?
Old May 16, 2008 | 06:06 AM
eddiebob's Avatar
Torque is the moment of a force; the measure of a force's tendency to produce torsion and rotation about an axis, equal to the vector product of the radius vector from the axis of rotation to the point of application of the force and the force vector.
In other words if you apply 10 pounds of pressure to a 1 foot ratchet you would have 10 ft pounds of torque (10 pounds x 1 foot= 10 ftlbs). Ed B
Old May 16, 2008 | 07:06 AM
xtoyz17's Avatar
Eddie beat me to it.
I'm guessing ratchet and box end was at least a foot so you're at or over what you needed. If it's not leaking I wouldn't think twice about it.
99DodgeGuy
Nov 15, 2006 05:26 PM
runamuk
Sep 5, 2006 05:58 AM
yarddog
Jul 27, 2005 09:52 AM
mkubacak
32
Jul 18, 2005 10:37 PM
