Sponsored by:
Sponsored by: CARiD
It's official. A 1500 Ram with a Cummins
Old Jan 24, 2007 | 07:40 PM
  #31
DynoDynamicsNE's Avatar
All this discussion about economy/power in diesels reminds me about an article I read a while back about the same subject. The article - I can't quote it because it was almost a year ago - said that up to a point, the more power you get out of a diesel due to proper tuning, the better efficiency you get as well. The article used a Duralax as an example. They tuned it to get quite a bit more power, and increased the mpg too. I don't remember the numbers, but I was impressed.
I don't remember if it said anything about emissions, so that may be what DC and Cummins are after, and not power/efficiency.
Old Jan 24, 2007 | 08:48 PM
  #32
Begle1's Avatar
I'm thinking that's perfectly accurate. The power you get is the main part of removing emissions parameters; all emissions parameters degrade when it comes to efficiency is the .5-1 MPG that some people see when they install programmers. When it comes to fuel efficiency, that is the maximum limit that these trucks can run at; and really, that isn't much of a handicap considering that the alternative is an EGR valve and that there seems to be a 2 MPG standard deviation between all of our trucks anyways.
Old Jan 24, 2007 | 09:55 PM
  #33
mr T's Avatar
Originally Posted by sqrl$$
Mr T, I don't think this is a mild difference in mpg if you are comparing the hemi currently offered in the 1500 which gets 12-14 mpg running empty vs this new diesel for the 1500 they are offering which is supposed to get 21 mpg city and hwy combined, that means a possible 22-24 mpg on the hwy. Never been a Hemi that will touch that in mileage, plus the benifit of 500 lb/ft of torque. Comparing to the 2500 diesel, I agree that the milage difference is minimal, but if you put the current 5.9 in a 1500, the front end would be wore out in 5000 miles. This new v-8 diesel is very close in weight to the current hemi, I believe I read they were within 100 lbs. I do agree that they should have just based it off of the current 4 cyl cummins but I do see that they have to keep up with or set the bench mark for the other auto makers.
i know what u mean...between the hemi and this diesel there would not be a comparison...im comparing the the projected mpg of the 3.0 diesel in the liberty..im not impressed by that at all...now if we're gonna get 22mpg highway in a 1/2 ton diesel when chev offers gassers that have that mpg on the highway then we have aproblem...know what i mean?...i am one of those people that can't wait for a smaller diesel to come into a 1/2...but i expected better mpg forecasts ...it is the mpg that generally has the big selling leverage over the gassers
but yeah anythign looks nice on fuel after the hemi
Old Jan 24, 2007 | 10:26 PM
  #34
96_12V's Avatar
Originally Posted by tomd
A V6 Diesel?
Sounds difficult
Here you go (it's a neighbor's engine here...)
http://www.maxxforce.com/products/de...d=1&itemid=001
Reasons for not putting a 3.9BT 4-cyl into a Durango/1500...
--Noise Vibration Harshness (NVH)
--Intended for commercial, lighter heavy-duty equipment applications.
--Emissions regulations
--Weight
--Cost $$$$$$$
--Life cycle/intended use
--Image of "V8 means Fast, Power, American..." "And 4-cyl is wimpy"
--Soccer Mom's transport, meaning quiet, comfortable, etc.
--2007 emissions
--2010 emissions
--25 years on any engine platform is long enough...??
Old Jan 25, 2007 | 12:10 AM
  #35
XLR8R's Avatar
This holds true for spark ignition engines as well.
Old Jan 25, 2007 | 07:31 AM
  #36
I realize that, I guess the key words are "up to a point". But gasoline has less energy than diesel, gallon for gallon. Tuning a gasser for more power usually results in less mpg, while tuning a diesel usually results in better mpg. Of course, there are limits on both before they start going the other direction, but the diesel has a higher limit than gasoline.
Old Jan 25, 2007 | 09:17 AM
  #37
TXTad's Avatar
Originally Posted by patdaly
AMEN!
They ALREADY have the 4 Cylinder version of the 6, so why not use it?
I just do not understand Engineers sometimes ( even though I are one )
It's not the engineers. It's the marketing pukes. They probably figure they'd have a hard time selling a 4 cylinder truck. So, a V-6! It's got the sexy V, and the number of cylinders that Americans think are minimum for power.
Old Jan 25, 2007 | 09:21 AM
  #38
TXTad's Avatar
Originally Posted by mr T
...i mean 20mpg city and 24mpg highway out of a 3.0 diesel in the jeep??....gimme a break.....i slmost get that out of a 7000lb truck...i expect nothign less that 30+ mpg on the highway to attract me to buy it...i expect more considering that gm offers 1/2 tons trucks equipped with the 4.8 V8 asser and that gets more than 20mpg on the highway
There is something about those Liberties that causes them to get surprisingly BAD fuel economy. A friend of mine had one that could hardly break 14 mpg. 20-24 is quite a big improvement in that context.
Tad
Old Jan 25, 2007 | 10:35 AM
  #39
flyfish's Avatar
Some additional info;
http://www.autoweek.com/apps/pbcs.dl.../70124002/1528
Old Jan 25, 2007 | 10:58 AM
  #40
XLR8R's Avatar
Actually, when you tune a gasser (or a diesel ) for more power (up to a point, as you said - which implies significant yet modest power increases - not doubling the HP/cubic inch!) you effectively raise the Brake Specific Fuel Consumption to a higher value, usually by increasing the engine's volumetric efficiency...
BSFC is a direct measurement of an engine's ability to convert fuel into work, in this instance moving a vehicle, which translates directly into MPG.
Old Jan 25, 2007 | 11:12 AM
  #41
BowtiedCTD's Avatar
well considering that i have heard of higher HP duramxs in the 30 MPG area not sure how to understand wat yall are talkin about
Old Jan 25, 2007 | 12:57 PM
  #42
mule3010's Avatar
I've heard of bigfoot too but I haven't seen one. The same goes for a 30mpg duramax.
Joe
Old Jan 25, 2007 | 01:04 PM
  #43
XLR8R's Avatar
Well, one of my dad's customer's best friend's buddy's girlfriend's sister-in-law's cousins said he read that on some dudes blog...
Old Jan 25, 2007 | 01:53 PM
  #44
CRIMPS's Avatar
HAHAHA
I have to admit...before I saw the light and starting researching diesel engines, I was put off by the Cummins because I wanted a V8!! I was headed to the Ford Powerstroke because there was no way I was going to own a pitiful little I6!!
Z
Old Jan 25, 2007 | 02:36 PM
  #45
mr T's Avatar
i almost spilled my coffee (yes tim horton's)
