Sponsored by:
Sponsored by: CARiD
How Much Does a Gallon of #2 Weigh
Old Oct 28, 2006 | 10:35 PM
nelrod's Avatar
homina homina homina, going once, going twice, SOLD to the 7 pounders
Old Oct 28, 2006 | 11:43 PM
annabelle's Avatar
We use 7lbs for aircraft fuel.
Old Oct 29, 2006 | 12:18 AM
Duallydog's Avatar
So it's 6 pounds per gallon? LOL
Old Oct 29, 2006 | 12:44 PM
Mainemike100's Avatar
What kind of gallon?
Most sources list #2 as 7-7.2 pounds per imperial gallon. So a US gallon would be just over 6 pounds, with some variation depending on the time of year and mixture. Figuring 7 pounds would be more than safe for a buffer.
Old Oct 29, 2006 | 12:49 PM
Geico266's Avatar
Welcome to DTR
Another pilot!
Fronty Owner's Avatar
I remember it from the aviators 6-7-8 rule for gas, oil and water.
6 ppg for av gas
7 ppg for oil
8 ppg for water
Old Oct 29, 2006 | 02:08 PM
XLR8R's Avatar
But wouldn't the 6 ppg be for 100LL? Jet-A should be 7...
Old Oct 29, 2006 | 02:26 PM
Iron Mike's Avatar
Fresh Water weighs 8.34 lbs a US gallon.
I believe diesel is 6.5 lbs per US gallon but that might be for jet fuel. #2 might be closer to 7. My book is locked up in my leads office.
I'll let you know for sure tomorrow
Old Oct 29, 2006 | 08:31 PM
GreatWhite91's Avatar
According to the density listed on Wikipedia, 7.09 lb / gal
Old Oct 29, 2006 | 08:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
But if you put it on a treadmill............
Old Oct 29, 2006 | 08:37 PM
XLR8R's Avatar
Of course, that's only on Earth...
Old Oct 29, 2006 | 08:39 PM
Geico266's Avatar
And the position of the moon also,, the moons gravitational pull will effect it also.
(I'm beginning to sound like Begle1 aren't I... .)
Old Oct 29, 2006 | 08:49 PM
XLR8R's Avatar
Hmm - you're not from the same gene pool, though...
Old Oct 30, 2006 | 12:45 AM
neveragain's Avatar
The weight of #2
Infidel you use my kind of numbers. ( Not that I knew that kind of accuritacy) I am most impressed.
Old Oct 30, 2006 | 11:10 AM
infidel's Avatar
Originally Posted by neveragain
Infidel you use my kind of numbers. ( Not that I knew that kind of accuracy) I am most impressed.
Essential to use accurate numbers in research to get repeatable results. Much easier and accurate to use fuel weight rather than volume then convert it when taking measurements.
A new word for you to look up that makes measuring liquids accurately hard:
meniscus
