Sponsored by:
Sponsored by: CARiD
How big of engine hoist for the cummins?
Old Feb 26, 2010 | 09:55 AM
jesussaves's Avatar
Im looking for an engine hoist what capacity should i look for?
Old Feb 26, 2010 | 11:09 AM
lgp9999's Avatar
I've never weighed one myself, but the numbers I've seen put both the 12v and 24v in the 1100-1200lb range. Most engine hoists I've ever used have at least a 1 ton capacity, so a normal one should do the trick. Bigger would probably be a little better for some extra peace of mind, but I'd attempt the job with your normal every day cherry picker.
Old Feb 26, 2010 | 11:18 AM
rebal's Avatar
I have a 2ton hoist at its shortest setting ,But at its longest reach its 1/2 ton and thats were it needs to be to pull one out of a Dodge and it will lift it out with most stuff stripped off the engine and the back of the hoist having 200 lbs on it the little 5.9 is a heavy bugger
AlpineRAM
Jan 26, 2007 02:57 PM
65fury
Oct 30, 2006 08:43 PM
westcoaster
May 31, 2004 02:19 PM
PeteRR
May 8, 2004 04:13 AM
