Sponsored by:
Sponsored by: CARiD
Grades of Diesel Fuel - Good Read...
Old Jul 19, 2006 | 05:17 AM
Katmandu's Avatar
Thumbs up Grades of Diesel Fuel - Good Read...
http://www.dieselnet.com/standards/us/fuel.html
Diesel Fuel Grades
Historically, the quality of automotive fuels in the USA was governed by ASTM standards. Diesel fuels are covered by the ASTM D 975-04a specification, which describes seven grades of diesel:
Table 1
Diesel Fuel GradesGradeDescription†Max SulfurNo. 1-D S15A special-purpose, light middle distillate fuel for use in diesel engine applications with frequent and widely varying speeds and loads or when abnormally low operating temperatures are encountered. Higher volatility than that provided by No. 2-D fuels.15 ppmNo. 1-D S500500 ppmNo. 1-D S50005000 ppmNo. 2-D S15A general-purpose, middle distillate fuel for use in diesel engines, especially in applications with relatively high loads and uniform speeds, or in diesel engines not requiring fuels having higher volatility or other properties specified in Grade No. 1-D fuels.15 ppmNo. 2-D S500500 ppmNo. 2-D S50005000 ppmNo. 4-DA heavy distillate fuel, or a blend of distillate and residual oil, for low- and medium-speed diesel engines in applications involving predominantly constant speed and load. † Based on the appendix to ASTM D 975. The D 975 is inconsistent in its description of the applications of the different fuel grades given in the scope statement and in the appendix.
Heavier fuel oils Grade 5 and 6 (residual), which are used primarily for heating purposes, are described by ASTM D 396.
The Sxxx designation was first adopted in the D 975-04 edition of the standard to distinguish grades by sulfur content. The S5000 grades correspond to the “regular” sulfur grades, the previous No. 1-D and No. 2-D. S500 grades correspond to the previous “Low Sulfur” grades (D 975-03). S15 grades are commonly referred to as “Ultra-Low Sulfur” grades or ULSD.
Further ASTM specifications exist for marine diesel fuels. While some marine diesel engines use No. 2 distillate, additional ASTM specifications identify four kinds of marine distillate fuels: DMX, DMA, DMB, and DMC:
  • DMX is a special light distillate intended mainly for use in emergency engines.
  • DMA (also called MGO) is a general purpose marine distillate that must be free from traces of residual fuel. DMX and DMA fuels are primarily used in Category 1 marine engines (< 5 liters per cylinder).
  • DMB (“marine diesel oil”) is allowed to have traces of residual fuel, which can be high in sulfur. This contamination with residual fuel usually occurs in the distribution process, when using the same supply means (e.g., pipelines, supply vessels) that are used for residual fuel. DMB is produced when fuels such as DMA are brought on board the vessel in this manner. DMB is typically used for Category 2 (5-30 liters per cylinder) and Category 3 (≥ 30 liters per cylinder) engines.
  • DMC is a grade that may contain residual fuel, and is often a residual fuel blend. It is similar to No. 4-D, and can be used in Category 2 and Category 3 marine diesel engines.
  • Residual (non-distillate) fuels are designated by the prefix RM (e.g., RMA, RMB, etc.). These fuels are also identified by their nominal viscosity (e.g., RMA10, RMG35, etc.).
With the growing importance of alternative diesel fuels, specifications are also being developed for biodiesel fuels and their blends.
Sulfur Content
Since the 1990’s, fuel quality has been increasingly more regulated by the US EPA under the authority of the Clean Air Act. In the context of the increasingly more stringent diesel emission standards, the most important fuel property regulated by the EPA became the sulfur content. Historically, the sulfur content in diesel fuels for highway and nonroad vehicles was limited to 0.5% (wt.) by ASTM specifications. The milestones in US environmental regulations limiting sulfur levels in diesel fuels can be summarized as follows:
  • Highway Diesel Fuel
    • 500 ppm: Sulfur limit of 500 ppm = 0.05% (wt.) became effective in October 1993. This fuel, commonly referred to as the low sulfur diesel fuel, was introduced to facilitate sulfate particulate emission reductions, which were necessary for meeting the 1994 emission standards for heavy-duty highway engines.
    • 15 ppm: Diesel fuel of maximum sulfur level of 15 ppm will be available for highway use beginning in June 2006. This fuel, referred to as the ultra low sulfur diesel (ULSD), was legislated by the EPA to enable catalyst-based emission control devices, such as diesel particulate filters and NOx adsorbers, which will be necessary for meeting the 2007-2010 emission standards for heavy-duty engines, as well as the Tier 2 light-duty standards.
  • Nonroad Diesel Fuels
    • 500 ppm: Sulfur limit of 500 ppm becomes effective in June 2007 for nonroad, locomotive and marine fuels.
    • 15 ppm: Sulfur limit of 15 ppm (ULSD) becomes effective in June 2010 for nonroad fuel, and in June 2012 for locomotive and marine fuels. The ULSD has been legislated for nonroad engines to enable advanced emission control systems for meeting the Tier 4 nonroad emission standards.
The above sulfur limits do not apply to heavy oils used in Category 2 and 3 marine diesel engines.
Last edited by wannadiesel; Jul 23, 2006 at 12:10 PM. Reason: copyrighted material removed
Old Jul 23, 2006 | 11:49 AM
Equalizer 2's Avatar
Interesting read, especially the link to the biodiesel.
Old Jul 23, 2006 | 12:42 PM
BigBlue's Avatar
I found this interesting.
Highway Diesel Fuel
04ctd
Dec 14, 2008 05:45 PM
Katmandu
Feb 25, 2006 08:21 PM
besserheimerpha
Jan 4, 2005 12:43 PM
redram
Feb 14, 2003 01:49 AM
