Sponsored by:
Sponsored by: CARiD
Glowshif Gauges
Old Mar 28, 2023 | 07:56 PM
Ram01787's Avatar
Glowshif Gauges
Glowshift Gauges are complete GARBAGE. I had 6 of them on the shelf for a couple years then installed them on a customer truck and only one worked. The others were either WRONG or just not functioning.
Bought....
- dual air pressure
- battery voltage
- transmission temp
- fuel level
- low rail psi
- high rail psi
The only one that was even close to accurate was the Voltage on an auxiliary battery. By close, it was OFF BY 2 VOLTS.
The other 5 were just wrong when tested. PURE JUNK
In addition the high rail pressure unit caused a P0193 code that would not go away. It also created a misreading of rail pressure from the OBD scanner.
The Low pressure unit was just stuck on 30psi......had to install an inline Autometer to test the function.
IT IS CHINESE GARBAGE...not reliable just lights that don't even stay on the level set.
Old May 7, 2023 | 03:19 PM
melani's Avatar
Very nice car! How long have you had it ?
91oldranchtruck
Feb 22, 2011 11:57 PM
dwl2002navy
Jul 3, 2010 07:41 AM
Midnite Warrior
Feb 15, 2009 11:43 AM
JC7588
Jan 23, 2008 12:11 PM
Dodgezilla
Jul 11, 2007 07:19 AM
