Sponsored by:
Sponsored by: CARiD
freightliner mt45
Old Jan 26, 2004 | 09:15 AM
gwhammy's Avatar
freightliner mt45
I've found a 2001 wrecked freightliner with a 5.9 and an automatic in it. Freightliner web sight says it is either a at545 or a at545n but I can't find any specs on this trans as to how much hp. one of these will take. Van has 51000 miles on it and can be bought real right! How hard is it to hook up computer in a engine swap? Thanks
Old Jan 26, 2004 | 04:19 PM
Monty's Avatar
The AT545 is built by Allison Trans. I hate to say it but this tranny is basically Allisons throwaway.
The max input power on a 545 is 235hp and max input tq is 445lb ft.
I believe the AT545N is the same tranny but with a neutral position that allows for "park brake" position on the shift selector.
One of the problems you will find if you plan on doing a swap on the ISB is that Freightliner uses a 100pin ECM opposed to Chryslers 50 pin version. With the left side of the ECM monitoring and sending outputs to the engine, and the right side sending output and receiving date from the OEM side.
However, this engine will have heavier components and a slightly different cam profile than the Dodge version.
Old Jan 26, 2004 | 06:49 PM
gwhammy's Avatar
The basic long block will exchange with the one in our dodges I'm guessing?
Old Jan 26, 2004 | 06:57 PM
Monty's Avatar
Yes
robsredford
Jan 29, 2006 09:38 AM
trucksforu
Aug 1, 2005 09:57 PM
gman07
Jul 2, 2005 10:10 AM
Jim Shulmister
Feb 20, 2005 07:04 PM
Haulin_in_Dixie
Nov 2, 2003 04:38 PM
