Sponsored by:
Sponsored by: CARiD
DTR's Truck of the Month June 03
Old Jun 1, 2003 | 11:16 PM
phox_mulder's Avatar
Re:DTR's Truck of the Month June 03
[quote author=HeberRam link=board=8;threadid=15341;start=0#144688 date=1054526803]<br>I have a question, for you , I see you have a lift and you post a 3&quot;?? I have a 2&quot; leveling kit in the front, and barely have I mean 1/32&quot; of clearance running 315/75/16's on after-market 16x8 rims, because of the off-set in the rims...I need , 3&quot;'s like you for clearance. Was that lift an aftermarket, if so pls let me know, or, did you increase the spacer on the 2&quot; leveling kit, and same in the back??? I am jealious you know of your truck, and need advise.. :'( :'(<br><br>Thanks, Steve<br>[/quote]<br><br>I'll jump in with a quick response, I'm sure Rob'll add in whatever I've missed.<br>He has Skyjacker springs in front, which netted him the 2 1/2 level in front. (D25 springs if I'm not mistaken)<br>He also has a 3-inch body lift, which lets him clear the tires in front no problem.<br>He'll have to give you the particulars of the body lift, as they aren't as easy on our Diesels as they are in gasser Dodges.<br>(the intercooler needs to be relocated, or extended, or something like that)<br><br>Which came first, the dump bed or the body lift?<br>Did the dump bed create the need for the body lift?<br><br><br>phox
Old Jun 2, 2003 | 10:45 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Happy Birthday Rob. 8)<br><br>Ed
Old Jun 2, 2003 | 06:04 PM
Scubasteve's Avatar
Rob, that is one nice rig you have there. Its nice to see a proffesionally modified piece of equipment whick is still useful as a daily driver.<br><br><br>Well done<br><br>Jason 8)
Old Jun 2, 2003 | 10:48 PM
HeberRam's Avatar
Phox...You da man.....You answered, my question and gave me a solution at the sametime..If I get this right, alls I've got to do is, get say 2-1/2 -3&quot; skyjacker or whatever, front replacement spring, &quot;chuck&quot; the 2&quot; spacer, and add whatever I added to the front to the rear axel...right?? Then, I won't have to get, new shocks, screw with the intercooler, track bar, steering stuff, body lift and whatever? I think if that will work, I'll save the body lift for my own ragged &quot;ssa&quot;.<br><br>Steve<br><br>P.S. if you spell the bad words backwards, the computer and the ADMINs...go ***????
Old Jun 2, 2003 | 11:31 PM
Rob Thomas's Avatar
Thanks, Stake, Steve, Ed , Jason, and phox for filling in Steve!
Steve, Phox is correct, 2-1/2&quot; D25's and the 3&quot; body lift is the ticket for additional clearance. The brand is Performance accessories, and they dont make one for the diesel equipped truck, so some modifications have to be made. If you search in the TDR fourms, under &quot;Body-lift&quot;, I give all the particulars/pitfalls about it. I don't regret doing it, I love it, and wait till you swap injectors, or do head work, piece 'o cake.
Phox,
The dump was waaaaay first, in fact it was my first modification (truck was a mear 4 months old), I did it for work reasons, it is very funtional, no drawbacks.
The body-lift went on just this last January, initially for ease of injector swapping/more engine compartment room (hence the relocated batteries), then I found other benifits from the lift. Ease of bell housing bolt removal(6-speed is huge), am now able to remove the shift tower from under the truck, without removing the interior console, ease of trans support/crossmember removal, more clearance for wider wheels (new 10&quot; now, and no rubbing on anything, and removed my steering stops), also now I added a front reciever hitch without modification to the facia, which I couldn't do without the body-lift, direct bolt on now, and generally more room/access everywhere, asthecis of the lift were only a bonus, but I do think it looks nice.
So anyway, no, the dump did not require the body-lift, however the dump made the body-lift more of a PITA to install. On a &quot;Normal&quot; truck, the body-lift should take not longer than a few hours, throw a dump in the mix, and add a day to that.
Rob
Old Jun 2, 2003 | 11:36 PM
StakeMan's Avatar
[quote author=HeberRam link=board=8;threadid=15341;start=15#145107 date=1054612125]<br>P.S. if you spell the bad words backwards, the computer and the ADMINs...go ***???? <br>[/quote]<br><br> :
Old Jun 4, 2003 | 12:35 PM
Joe Diesel's Avatar
this is might be a stupid question.... but how do the stacks work with them attached to the lift bed???
Old Jun 4, 2003 | 02:11 PM
Diesel Dan's Avatar
Heberam,<br>Another option is using Rancho's 3 in spacer. it is listed for the 1500 but i checked w/rancho and they say is is made the same as the 2 in for the 2500. I have the 3 inch spacers and they work great.
Old Jun 5, 2003 | 04:27 PM
[quote author=DieselDude link=board=8;threadid=15341;start=15#145665 date=1054748154]<br>this is might be a stupid question.... but how do the stacks work with them attached to the lift bed??? <br>[/quote]<br><br>I think he has pictures in the members photos of how it works.<br>If not, there was a thread about them either here or TDR with pics.<br><br><br>phox
Old Jun 6, 2003 | 07:31 AM
HeberRam's Avatar
Diesel Dan...That might be even better, I already have the Rancho 2&quot; leveling kit, and if all I got to do is change the spacer better yet!!! If I have any problems, I might PM you for your local contact..My only concern, and obviously proof is in the pudding, and your pic shows it can be done, is the spacer constructed the same as the 2&quot; for dodge diesels as far loading ( strong enough)?? I know the local installer will probably tell me no, and try to sell me a 4-1/2&quot; lift....<br><br>Steve
Old Jun 6, 2003 | 07:48 AM
GrandpasRam's Avatar
Rob, really nice truck, congrats. I really like the job you did with the dump-bed, it really looks super.
Old Jun 6, 2003 | 11:15 AM
TXRAM2's Avatar
Rob, One word AWESOME ;D
Old Jun 6, 2003 | 02:21 PM
AKDSLDOG's Avatar
Congradulations!!!!! Very nice lookin ride! 8)
Old Jun 6, 2003 | 06:59 PM
Dieseldude4x4's Avatar
[quote author=DieselDude link=board=8;threadid=15341;start=15#145665 date=1054748154]<br>this is might be a stupid question.... but how do the stacks work with them attached to the lift bed??? <br>[/quote]<br><br>I saw this truck in Kentucky. It has like ball and socket arrangement like on the big Euc trucks if I remember right. When the bed is down, the female half of the ball and socket seats over the male half and forms a somewhat seal. It is a very cool set up for sure.
Old Jun 6, 2003 | 08:59 PM
Haulin_in_Dixie's Avatar
Cab over big trucks used the ball and socket deal for many years. Stacks bolted to the cab and raised with the cab for service.
