Sponsored by:
Sponsored by: CARiD
Dozer lacking on power
Old Apr 14, 2008 | 08:10 PM
dieselrob's Avatar
Got a dresser td 7e. Its lacking on hydraulic power. Engine seems to run on full power but is seems to loose drive power to the tracks. Sometimes it runs fine then if a dog the next couple days. Gonna change the filter on the hydraulics, but it just seems weird that its fine sometimes and weak others. Any one got some thoughts or a place to look on the net for info on dressers?
Old Apr 14, 2008 | 08:29 PM
Totallyrad's Avatar
I don't know about Dressers specifically but your question seems confusing. Is it lacking hydraulic power, power to the drive motors, or both. The transmission normally has no bearing on the hydraulics or visa versa, unless it's just made that way. Normally, you will have a filter on the transmission. You could also have a plugged pick-up screen in the transmission, bad charge pump, or sticking brakes. You might try here. http://www.heavyequipmentforums.com/Forum/index.php?
http://www.google.com/search?hl=en&r...forums&spell=1
Old Apr 14, 2008 | 08:43 PM
dieselrob's Avatar
I mean the drive motors. The brakes arent sticking, its just somedays it will push like hell other days is got no drive power. I can remember a time or to is was a dog and then all a suden you felt it kick in and get its power back.
Old Apr 14, 2008 | 08:56 PM
Totallyrad's Avatar
Try a filter change like you're planning and make sure the fluid is topped off. If that doesn't do it, you might try to locate an old shop manual for it. Try Ebay, they have tons of manuals there.
Old Apr 14, 2008 | 09:43 PM
dieselrob's Avatar
Thanks for the insight ill see how it turns out.
Old Apr 14, 2008 | 09:45 PM
bullfrog5.9's Avatar
at my work since ive been there we hav done two td7 trans and converters there are way to see if trans is gone or if it trans u can hook up pressure gauges to some lines and even valve body .ill talk computer phone to work and show boss what ur problem is and see what he says. how old is it does it hav cummins or other in it and how many hours
IntakeRacing
Nov 9, 2008 11:28 PM
jazzlynn
May 3, 2008 08:14 PM
abc4yew
39
Oct 20, 2006 01:56 AM
efrantz
Apr 29, 2006 12:44 AM
SHARPMACHINE
Feb 23, 2005 09:51 PM
