cummins diesel longevity question?
That would tend to be my suggestion as well. The '94's had the same pump and such, but it was the first year of the 2nd gen Dodge truck, so there could be more problems with the truck itself--though I havn't had personal expernace with this.
As my sig says, I'm in the 280k range with my 1996 5-speed, (although it's a 2wd, never had a 4wd) I will share with you what I've done in fours years of running this truck. I have replaced the following (and apx cost):
--Steering box $850
--Front rotors/Calipers/pads $685
--Rear drums & pads $480
--Fuel sender modul (in tank) & corroded fuel supply/return lines $350
--Starter $295 (found out afterwards on this site that rebuild kits are avalible for around $50, oops!)
As I reflect on this list, it seems like a lot but then I remember the mileage it's at and I'm running about 21 mpg overall and it does not seem so bad. All of this execpt the fuel lines does not involve the engine whatsoever.
One final thought for you--as you look at rigs to possibly buy, take a moment to sign up for a CARFAX or autocheck account with unlimited access for a month. Run a check on EVERY truck you consider at all. I found some alarming things when I ran a few I looked at through--like the '95 ex-cab 4wd with about 125k That looked a great deal for $9995, until I found out it had been lemoned! This is the sort of thing dealers won't know unless you ask for this report and private owners likely won't tell you. Cover your tail as you shop.
--Steering box $850
Originally posted by 96_12V
One final thought for you--as you look at rigs to possibly buy, take a moment to sign up for a CARFAX or autocheck account with unlimited access for a month. Run a check on EVERY truck you consider at all. I found some alarming things when I ran a few I looked at through--like the '95 ex-cab 4wd with about 125k That looked a great deal for $9995, until I found out it had been lemoned! This is the sort of thing dealers won't know unless you ask for this report and private owners likely won't tell you. Cover your tail as you shop. [/B]
coadman
Hey, I found a 1998 3500 4x4 5 speed with 55K miles on it(I questioned the salesman over the phone, asking him, if he was sure it wasnt 150K(LOL) Anyway, I may go look at it this weekend, it is in Oklahoma City, and I live in southern Kansas. I did notice that it had the 24 valve motor, so is that anything to be concerned with? Since they changed from the 12 v to 24 late in 1998, is this first year model one "prone" to bugs?
thanks,
coadman
thanks,
coadman
Originally posted by infidel
They're all 12 valves too I'll bet. I work on quite a few trucks and have never seen a 24 valve with over 250k on it while I know many 12s with over 500k.
coadman - will have more problems than a 2002...but they have pretty well been documented...and if the price is right, you can calculate what it will cost you to get it primo!
If you get serious about that truck, don't overlook carfax.com., especially in OK.
Need someone to look it over?, talk to Dan...@ City Muffler in OKC. (a DTR advertiser).
RJ
coadman - will have more problems than a 2002...but they have pretty well been documented...and if the price is right, you can calculate what it will cost you to get it primo! If you get serious about that truck, don't overlook carfax.com., especially in OK.
RJ [/B][/QUOTE]
The "price" is very attractive, quoted me a price of $16,999.00. I kind of figure like any dealership, cash outright purchase should knock between $1,000-$2000 off of final figure. I have already checked it out on carfax, a one owner truck. Where at in this forum, can I read about the "documented problems" you refer to, about this year of truck?
thanks,
coadman
RJ [/B][/QUOTE]
thanks,
coadman
Only items I recall are exhaust manifolds tend to crack and some 5 speed tranny problems....but I don't pay close attention to the 98's. I would start a new thread under "24 valve Engine & Drivetrain" asking for what to look at closely. That would be your fastest way of compiling a list.
Did a search under "1998 problems" and found this thread to get you started. There were others! https://www.dieseltruckresource.com/...=1998+problems
Good Luck!
RJ
Good Luck!
RJ
Look at HaulinDixie, he had 250,000 plus on a #53 block pulling 30,000lbs daily! I've got 100,000 miles on a 53 with a TST PM3 and pulling 30,000 +lbs for 30,000 miles of it and haven't had problems. I don't think it's fair to judge the 24V just yet.
most of the time I run empty... Mostly running back and forth to my jobs (Traveling computer tech)...
So under light duty and mostly highway miles I haven't seen any big repairs except for...
* front driveshaft
* rear pinion seal
* thermostat
That's it! - Check the signature! It's a good truck!
* front driveshaft
* rear pinion seal
* thermostat
coadman
My 95 has 518k miles on it. Outside of the usual service work, minor repairs and replacing a tailpipe, it's held up very well. Now the 01 Sport has had a few things done to it, but it won't make the older model mileage. The body will go first.
Friend on mine just got shafted IMO here about 3 months ago on a trade in. He had a 95 Dodge CTD 12V single cab 5-speed dually 4x4 with sleeper, jet black in color, interior gray, all stock, never modified with 106K miles and I mean cherry condition IMO. He bought the truck new in 95 and this guy really had a problem with detailing,(this is on any vehicle he owns) always keeping one showroom clean and maintained. I'm bad at times on detailing my ride, but this guy needs to go to the loony farm.
With out saying anything to anyone about selling his dually at work he showed up one Monday morning driving a used 04 Chevy Z71 4x4 extended cab pickup. Proud as a little ole' puppy of his new ride and telling me I got a whopping $8500.00 for the 95 trade in. He said that sounded real good to me as old of a truck that 95 was. I tried my best to hold back the tears and agreeing thats a pretty new truck you got there John. I think he just got tired of it, said well I've had the 95 for 10 years. I said nothing else just smiled!
I say one thing someone got them a super nice 12v. So there out there, but may be once in a lifetime deal. Check um' out, Alot of people don't know what the got.
Tony
Tony
Tony
Tony
coadman
........have never seen a 24 valve with over 250k on it.....
Hey, even if I have to replace a VP once or twice, it pays for itself very quickly when you compare that to a monthly bank payment of $400 or $500 for a new ride.
