4bt smoking white
at work i have a fork lift that has a 4bt in it with the 4b version of the vp44 . it will not start and smokes very thick white . we drained the fuel and put fresh in so its not water in the fuel . theres no sign of a bad head gasket . wich leads me to think the pump died . i know that the vp44's have a habit of smoking like this when they die . what im guessing happened was they ran jp8 fuel in it [duhhh] and the mother board that controls it fried . just like when you run a vp44 with low fuel pressures . it gets hot and kills the pump. it has a mechanical lift pump . the fork lift has only 100 hours on it . any ideas would help. is there a way to test the pumps with out a scanner
If it only has 100 hours on it , call the dealer and let the warranty fix it...
Whats the brand of forklift?
its a sky traxx the problem with just calling the dealer is we have the fork lift in japan and theres not any dealers here on the island . [dummy] this is fun filled navy equipment plus im sure that they arent covered anymore cause i think there like 2003 models and yes still only have 100hrs
Ok , well the first things i could be doing , would be checking the fuel system (lift pump?) , then pop test the injectors and do a compression test, it's possibe that being that old , with that little use, that stuff is sticking , ie , piston rings, not to mention that they never got broke in to begin with.
On a side note , i have never seen a 4B or a 6B in industrial equipment with a VP on them , every one i have ever seen had a VE pump. |
it has a vp30 pump wich is a little brother to the vp44 we so love . its kinda a wierd set up cause it looks alot like a little 12v with a vp30 and its got a hx30 turbo it also runs a mechanical lift pump .after some looking around online i see that i has alot of the same problems as the vp44
