Sponsored by:
Sponsored by: CARiD
24 V ENGINES
Old Jan 7, 2003 | 09:16 AM
1ST CUMNZ's Avatar
24 V ENGINES
CAN ANYONE TELL ME THE DIFFERENCE BETWEEN THE<br>ECHO AND ISB OR ARE THEY THE SAME ?
Old Jan 7, 2003 | 09:36 AM
Commatoze's Avatar
Re:24 V ENGINES
Probably the single biggest difference is the common rail fuel system on the 03's. This technology, if I have it right, allows for multiple injection events during the compression cycle. Because there's an initial &quot;pilot&quot; combustion, there's no sudden rise in cylinder pressure. The result is a quieter engine. Cummins refers to it a &quot;socialibility&quot;...Ha! . Longer oil drain intervals, sel-priming fuel system, quicker wait-to-start times. Also, there's a new breather system eliminating the most of the drips on the the driveway.
-Tom-
Old Jan 11, 2003 | 08:00 AM
Pit Bull's Avatar
Re:24 V ENGINES
The biggest difference is the EPA
Old Jan 11, 2003 | 09:06 AM
PourinDiesel's Avatar
Re:24 V ENGINES
All 3rd Generation Cummins B's are an ECHO platform engine.
That is basically the ECHO style reinforced block.
It is mated with a Bosch Common rail fuel system, electronic injectors.
The Industrial/Commercial Engines are referred to as ECHO's.
They can have Variable Geometry turbo's, Wastegated turbo's.
Also they come with Delayed Exhaust Gas Recerculation systems.
The major difference in the ECHO engine is that the gear train is placed in the rear of the engine.
The Daimler Chrysler engine has the gear train placed in the front/traditional area.
Both displacements are still 5.9Liters, but they are redesigned and evolved other then that.
--Justin
cbx
May 18, 2009 07:23 PM
F11Engineer
44
Mar 26, 2003 10:57 AM
Commatoze
Mar 20, 2003 08:49 PM
