Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Best winter Additives
Old Jan 1, 2009 | 02:24 PM
dozer12216's Avatar
Cheapest and best for antigel !!!!!!!!!
Are you sure you want to look !!!!!!!!!
Kerosene.
Old Jan 1, 2009 | 04:46 PM
bhaugen's Avatar
Most of the pumps around here run a 50/50 of #1 and #2, plus I add in the White power service. We just had a -35 morning and it started and ran just fine.
Old Jan 2, 2009 | 08:42 AM
farmboykjb5.9's Avatar
I run power service 911 also cause last year i was running 5% bio and she started spitting and sputtering and i thought yeah right this stuff wont do anything well i was wrong she cleared right up so that convinced me, i also mix cen pe co additive with it too.
Old Jan 2, 2009 | 11:04 AM
John Faughn's Avatar
I have used all of the above , like them all , but 2 issues , one is finding what is good , at a good price , then best - is only done with testing , I would have to dig to bring the test of about 20 additives , the best I am still looking for a regular source , I buy by the gal. can not afford to get drums of it .
http://www.schaefferoil.com/soy_shield.html
Old Jan 2, 2009 | 11:15 AM
CrazyFloyd's Avatar
I used the schaeffer winter additive for my trip up to MN this year (and yes it was very cold for this texan). Unfortunately, I had to use a blow dryer on the new metal external inline filter that was installed when my lift pump went out. Bought a bunch of the PS white container and have had no problems since. Although, I think if I would have used more of the schaeffer I might not have had any problems. (Going back home tomorrow after a two week stay.)
Old Jan 2, 2009 | 11:51 AM
How much of either did you use ? How much fuel ?
I was speaking of the Soyshield , it has anti gel , but the soy-bio is the best for the lube issue , at least as far as the testing goes .
Old Jan 2, 2009 | 12:16 PM
CrazyFloyd's Avatar
I put roughly; a 1/3 of the bottle, which treats 125 gallons in its entirety, when I was on a full tank. I used a Schaeffer brand soy additive that works either in the fuel or in the oil before. I put a bottle of it in my wife's car and my truck's oil before I switched them to synthetic oil. When my fuel geld up I put enough PS additive to treat about 75 gallons of fuel when I had about 25 gallons in the tank.
Old Jan 2, 2009 | 12:38 PM
HecTiK's Avatar
Originally Posted by dslpwr81
A lot of the guys say I am excesive. That puts a whole new meaning to it. You may be going over board. You dont need the 911. Some will say you don't need any of it. Just use 16oz of white power service and/or some 2 stroke. IMO
I used the 911 because it did gel up. I originally had 20 oz of the white powerservice in but that didn't help that much.
Old Jan 2, 2009 | 01:43 PM
AkTallPaul's Avatar
Originally Posted by infidel
He probably needs the the 2 stroke though if he's using 911. That stuff drys your fuel out, as in takes away lubrication, and should only be used in emergencies.
Hence the name 9-1-1.
True....only use 911 in emergencies, It is not an antigell.
Kerosene.
Kerosene is #1 diesel....and yes it will gell up to. At about 60 below it starts getting thick
Old Jan 2, 2009 | 03:12 PM
patdaly's Avatar
At 60 below my BLOOD would be frozen......... Y'all are nuts up there!
Old Jan 3, 2009 | 12:35 PM
PADuallyBoy's Avatar
Cool
Power Service all the way!
Old Jan 9, 2009 | 05:56 AM
ofcmarc's Avatar
Howes.....Only.....oh an we run straight #1 in winter (sept-april)
Ever have problems with the Howes gellin'? I know several guys up here that run it exclusively but they started gellin' after the switch to ULSD. Seems to me that anecdotaly it dosen't work as well with the new brew of fuel.
Kero is Drier than #1 not quite the same.
I run a mix of Stanadyne Performance and 2-stroke.
Old Jan 9, 2009 | 06:20 AM
onetrucker1's Avatar
Opti-Lube Winter Blend , anti-gel and lubrication .
Old Jan 9, 2009 | 02:23 PM
AkTallPaul's Avatar
I've never had a problem with it gelling, course I run it year around. Our stations here make the switch in Sept. so if it chills down before you burn that last tank out it will gell up. I did that this year, since I drive a work truck home, I haden't driven my POV. So first day off I fired her up, ran 5 seconds an died. Threw in some howes an 911, changed filter, filled up housing with howes/#1 mix, put it together an fired her up an ran fine. Thankfully it was 20 above.
Your right about kero being a bit drier, heck I don't know if you can even buy it here, but for S's an G's its basiclly the same.
Old Jan 9, 2009 | 08:54 PM
chariotdriver's Avatar
Regular.....
......unleaded old boat gas has worked for myself. Just make it about 12:1 mixture (10 oz/gal) and it will take right off and it's far from a dry fuel. Beats the heck out of using starting fluid. I've spent some time down at McMurdo (very very cold) and they use it all the time on the equipment.
If it's not too extreme I've been using the Stanadyne performance formula for years. Buy it in 5 gal buckets and it's a pretty good deal.
cd
