Do I need an adjustable upper ball joint? Regular ball joint? Pics inside...
Dave, that's very helpful. I'll take those specs in to the alignment shop. Just curious, did you ever try these specs?
http://www.dodgeram.org/tech/specs/00_steer_specs.html
After replacing bad front rotors about 3 months ago now my truck drives GREAT. It steers straight and the PSC 3 turn steering gear (don't flame me on this...I know some don't like PSC but mines fine) with the light valving allows steering with one finger and no pull or wobble or wear.
Be sure to find a good FRAME shop for the alignment. I had no luck with the name brand alignment shops. A good FRAME alignment shop will know how to fix problems not just align it to spec.
Good Luck,
Dave
Yea but I don't usually drive with 4wd. All the wear you see is from 2wd pavement driving. I put the rear 245's on about 3k miles ago. I wanted to get the front aligned before I put new matching tires on the front. The front has been wearing like that before I even changed the rear tires.
You have been privileged to receive some exceptional input from Dave Miller. He reafirimed statement on very low toe settings. Caster must be within a narrow range. Camber should not vary more that .5 degree or you need the adjustable joints per statement. With a solid axle, you do not twist the axle to change cross values. That was proved in final settings.
Mike was impressed with the 3rd gen TB setup. PSC 3 turn box and DSS and other stuff I added. I have had a few guys call him up and he will talk to you about your problem. Mike knows his stuff and I highly recommend him.
I know it's been a while but I thought I'd just give you guys an update. I got it aligned at Tim Pearson's Alignment shop. I was going to take it to a frame shop but apparently this guy is "the best in town." I was very pleased with his honesty and service. Can't find them like that anymore. Anyway, truck drives like a dream! Wish I would've done this sooner. I can get the specs up later but from what I remember for caster, the driver's side was set to 3.31* and the passenger side to 3.50*. The toe was set to 0.10* and 0.15*.
My truck already had adjustable camber sleeves on the passenger side, as well as adjustable caster thingies on the lower control arms. I like how Tim didn't try to sell me a new set. He said that the inner tire wear is normal since these trucks have a solid front axle. He said you just gotta rotate the tires often in order to prevent it.
Alignment
Glad to hear you got it fixed. Did he adjust camber, caster or toe to get rid of the tire wear?
Did he get those caster and camber and toe adjustments using the control arm eccentrics or the offset cylinders on the knuckle or both?
EdmontonCanada
37
Feb 4, 2016 12:02 PM
RottnRam
Mar 28, 2010 09:51 PM
tennessee
Jul 11, 2009 11:37 AM
Common
Apr 27, 2008 12:47 PM
